Will a slight over-rev harm the engine?
Old Jan 7, 2003 | 06:03 PM
payneinthe's Avatar
Default Will a slight over-rev harm the engine?
The other day, I was cruising along and a car in front of me was going slow, so at about 70 mph, I went to downshift to 4th to pass and hit 2nd instead.
I felt the rev-limiter kick in and saw the red LEDs flash on the tach. Given that 70 is just a tad over the redline for second, I'm guessing that there's probably no damage. Is this a reasonable guess? Is there something I should do to confirm that everything's okay?
I've driven about 300 miles since then w/o problems.
Old Jan 7, 2003 | 08:23 PM
dlq04's Avatar
I suspect your OK. The limit in 2nd is about 64 mph and you may have exceed that some but probably not long enough to do any permanent damage. But that was not the rev-limiter kicking in that you felt. The engine rev-limiter is for up shifting during acceleration ONLY; it does not protect against mis-shift mistakes when downshifting! The price of over-revving the engine when downshifting is very expensive -- about $8,000 for a new engine. Consider yourself lucky.
Jamie_Murray
Mar 8, 2010 04:39 PM
alcxm5
Aug 12, 2009 11:12 PM
bobatimez
Jun 29, 2004 06:04 AM
patrick93
Oct 12, 2003 06:07 PM
zero_to60
Jul 31, 2003 04:59 PM
