Winter idea...
Old Sep 9, 2006 | 06:12 AM
  #31
SpitfireS's Avatar
DrCloud Posted on Sep 9 2006, 01:56 PM
The manual, as I recall, also says to keep your speed down.
Wouldn't that be because at that point you have the spare at the front?
IIRC the spare has a max top speed of 80 km/h (50 mph)
When one has, on all four corners, the 16" x 6 1/2" JJ wheels with 205/55/16 winter/snow tires those restrictions are not in order IMO.
That is, if one dares to drive that fast in snow anyway....
Old Sep 9, 2006 | 06:43 AM
  #32
DrCloud's Avatar
OK, go ahead and put OEM front wheels on the rear hubs and drive as fast and as much as you want. I really don't care if you ruin your car or yourself. This pissing contest business doesn't interest me, either. HPH
Old Sep 9, 2006 | 07:07 AM
  #33
SpitfireS's Avatar
Allthough you (DrCloud) are probably "done" here I would like to know where a healty discussion turns into a "pissing contest"?
Old Sep 9, 2006 | 10:14 AM
  #34
krazyguy316's Avatar
i was wondering since our car doesnt have much weight in the back. Would it be a good idea to put weights in the trunk?
Old Sep 9, 2006 | 04:41 PM
  #35
jaws's Avatar
Originally Posted by Emil St-Hilaire,Sep 8 2006, 05:14 PM
Beater.
That's amazing! A CRX from Quebec that is still on the road and hasn't found a place in rust bucket heaven? Wow.
Old Sep 9, 2006 | 08:06 PM
  #36
CKit's Avatar
Even with Blizzaks, my S2k was still slipping and sliding on a day that was just another boring day with the Honda Pilot.
Old Sep 10, 2006 | 08:08 AM
  #37
8kGoodENuff's Avatar
People usually put 50 lb sand bags in the back... maybe 2 or 3 to put that extra weight on the rear end.
What kind of wheels are usually used to slap on some winter tires then?
Andre
Old Sep 10, 2006 | 10:15 AM
  #38
E White's Avatar
Don't put weight in the trunk ... not needed.
The car is pretty well balanced. 50/50 front to rear.
Although some weight in the back will provide a little help in starting from a stop in snow ... it will adversely affect your handling at speed in the wet or in the cold on dry roads.
Old Sep 11, 2006 | 04:49 AM
  #39
You really don't need 50/50 weight distribution in the snow. You're not going to be driving spirited in the middle of a blizzard. So adding the weight to the back of the car would help dramatically so that the back end does not go loose.
Andre
Old Sep 11, 2006 | 05:21 AM
  #40
home38er's Avatar
If you need the extra weight in the car just keep the gas tank full to 1/2 full.
