Winter Storage
Can anyone provide any info on storing the S for the winter. It will be garaged for about 5 months. Should it be on jack stands? Type of stand and jack? Lifting points etc. Any help would be greatly appreciated.
Thanks
Thanks
Can anyone comment on using a gas stabilizer for the S2K? My coworkers have recommended it as a general rule. Another coworker recommended filling the snot out of the gas tank til it practically overflows - so that moisture can't get into the tank. Anyone?
I would do the following:
--Add gas stabilizer. Use this on my boat for 10+ years. Summer blend gas is more volatile, and you could get shellac type deposits in the fuel system.
--Fill tank on a moderate temp. day. I stopped filling my boat tanks when they expanded out the overflows one year due to temp rise..
--VACUUM, Clean, treat interior.
--Cover or protect paint from stuff falling on the car..
A friend of mine leaves his car on the ground (an M3) all winter long, and hasn't had any problems with tires, or suspension. Good luck.
S2000 Winter Storage (Thanks to Ohio Racer for this list - Pm him or me for the WORD Document) This is a copy of it.
The information presented in this document has been gleaned from several posts on the web site www.s2ki.com.
1. Change the oil and filter, unless you are still within the
Wow! Great advice.
Thanks for the all information. I'm looking into storing my car for the winter and that was excactly what I needed to know. I think I might be able to use alot of my winterizing chemicals (fogging oil, silicone spray, and fuel stabilizer)that I used on my SeaDoo on the S2K.
that's pretty thorough...some good stuff in there. I'm not so sure about all the stuff you need to do about mice, but if you are paranoid then why not!
I'm a beleiver that fuel stabilizer is just paranoid marketing....all you need to do is fill the tank
needans2k2
Jan 15, 2013 09:01 AM
Special_K_828
Jan 21, 2004 01:37 PM
