Wiper Blade Tip
Old Oct 12, 2001 | 07:07 AM
andrewewing's Avatar
Default Wiper Blade Tip
Although my car is only 10 months old my wipers were streaking so I went to PepBoys to get some refills. Decided to get new Bosch MicroEdge Excell blades instead. WHAT A DIFFERENCE. Like night and day, or like wet and dry. Best $25 I ever spent. There's a MicroEdge and a MicreEdge Excell. Be sure to get the Excell, it has 2 kinds of rubber. You will need a 16 inch and a 20 inch. Fit perfectly on the S2k and look stock.
Old Oct 12, 2001 | 07:29 AM
jschmidt's Avatar
Here's another tip: Whenever you clean your windshield clean your blades too. They get contaminated with road grime and sometimes, cleaning them with a strong detergent can fix it.
Old Oct 12, 2001 | 09:00 AM
dlq04's Avatar
I agree completely - best by far I've used. I probably tried 1/2 dozen different manufacturers on my Maxima (which for some strange reason was much worse than any car I've ever seen). The Bosch MicroEdge Excell have been around a couple years now. I too high recommend them -- if you must take it out in the rain.
Old Oct 12, 2001 | 09:40 AM
gpiazza's Avatar
andrewewing,
Did you replace the frames or just the blades? Also, mineral spirits is great for cleaning the blades. It removes all the 'dead' rubber.
-Greg
Old Oct 12, 2001 | 09:42 AM
johev's Avatar
cleaning them with just a rag after washing the car and then cleaning the window really well and applying rainex has worked great for me...
Old Oct 12, 2001 | 09:58 AM
Greg, these only seem to come complete, blade and rubber and are about $11 each but the blades are nearly identical to OEM in appearance and a perfect fit.
Old Oct 12, 2001 | 10:35 AM
KenS2K's Avatar
Sponsor support:
HandA-accessories sells OEM replacement blades. Only $5.52 for the set.
Old Oct 12, 2001 | 03:56 PM
CoralDoc's Avatar
I just switched back to the OEM blades after using the Bosch blades for several months. Here in S. Florida the OEM blades last longer and work better - perhaps it's the sun.
Old Oct 12, 2001 | 06:43 PM
jschmidt's Avatar
Over the years when I've tried Bosch blades, I too didn't think they lasted very long. Haven't had them in a few years though. I stick with Anco now.
Old Oct 13, 2001 | 10:26 AM
gregstevens's Avatar
Banned
I just replaced my Anco's on the 4Runner that had been on there for about a year. I used the Excell and what a difference!
I can see, I can see!
Thanks for the recommendation!
