would rear sway bar increase steering ratio?
obviously, the only way to truly change the steering ratio would be to change the rack/pinion. but some have said that adding a beefier rear only sway would induce more oversteer? im no expert, but i'm in a ap2 chasing after the steering response of a ap1. would the sway help? and which company makes it?
thankx
thankx
Your steering angle like you said will not change.
Putting a "beefy" rear sway and strut bar will cause oversteer more so than stock. If the back end has no flex it has the tendency to slide as opposed to flexing a little and keeping grip. I'm having a hard time tryin to explain it but it makes sense to why some of these bars are adjustable depending on what you wanna do with your car. I have seen this theory work first hand in both a 240sx and Integra GSR. Hope that helps some.
thankx
thankx
Originally Posted by Elistan,Mar 28 2006, 06:09 PM
If you want AP1 steering response, I recommend upgrading your front tires as a first step.
I can talk from experience. I changed to a larger rear bar and received less rear body roll, but also received more oversteer. If you can handle that, it's great. I had trouble with it and changed back to a stock bar.
Originally Posted by RED MX5,Mar 28 2006, 06:09 PM
Shorter sidewalls usually equate to quicker steering response. Are the AP2 sidewalls really that floppy?
