Yes! 85 cents fix to Rick's windscreen
Old Feb 12, 2001 | 03:36 AM
Marco's Avatar
Banned
Ok, I put 5/16 hose on the edges, it definately stoped the rattle when screen is up, but when its lying down(which for me right now is always) every bump I hit it rattled.... new screen did not fit tight in stcock mechinizm... Well I found a way to get it to fit dead tight in the thingy....
bought a 4 pack of 1/4 flat rubber washers, and put 1 on each screw holding deflector in.. I put mine on bottom...meaning after screw goes throw deflector, but before its threaded into hole... the Epoxy I used to seal it is drying now and clamps are a must because now the space between the 2 black things is slightly wider... but now no movement and no noise.
Epoxy says its completely done hardening in 16 hr... so I will post at 830pm pst with it reinstalled in the car... but I think this fixed it
HTH
Old Feb 13, 2001 | 04:55 PM
Marco's Avatar
Banned
Ok tested it today... not a noise what so ever from windscreen now... with it up or down
rubber washers did the trick
HTH
btw, removed the 5/16 hose... no longer needed
Old Feb 13, 2001 | 05:16 PM
Rick Hesel's Avatar
Former Sponsor
Good work, Marco. There's always a simple solution.
Rick
hansai00
Sep 2, 2008 09:50 PM
SoichiroUK
May 28, 2007 03:46 PM
getshorty
May 21, 2007 07:40 AM
anthonys2k
Dec 19, 2004 06:28 AM
NVMY4N
Mar 1, 2004 11:44 AM
