Reducing wind noise with the top up
I noticed that with my top up, there's wind noise due to the convertible top not completely sealing with the windshield. Does anyone have any suggestions on how to alleviate this issue?
Should I try to add some sort of padding to make a tighter seal?
Originally Posted by jesusphish,Sep 2 2008, 01:45 PM
new strikers won't, necessarily, work. Unless they have significant wear where the latches connect, they won't work.
when you latch your top, pull up the ebrake and pretend you are trying to lower the top. Just do it for like a second, you'll notice the top will go down a little bit in relation to the top of the windshield frame. This helps it seal.
You can also try to tighten the screws on the strikers, or just replace the strikers.
Originally Posted by hansai00,Sep 2 2008, 09:42 AM
I might need some grease for the rubber. Is there something I can just buy at Kragen's? Perhaps some sort of silicon spray?
Originally Posted by daktruckie99,Sep 2 2008, 01:57 PM
If there were not significant wear, I'd tend to think he would not have a noisy top.
