Yet another hardtop question
Old Sep 8, 2009 | 07:37 PM
155mph's Avatar
Default Yet another hardtop question
I was just wondering- after one has the OEM hardtop installed how hard is it to take the hard top off and still use the soft top? If I wanted to put a hardtop on my car for weekends (so I don't get my soft-top slit with a razor...) will it be a total PITA?
Thanks
Old Sep 8, 2009 | 07:45 PM
f23power's Avatar
the hardtop itself is pretty light...its due to its size and shape that makes removal a two person operation
-a
Old Sep 8, 2009 | 08:20 PM
G's Avatar
G
Or you can build a hoist - that is where mine stayes most of the time. I use it to remove and install the HT as well as to store it. Below is the post we made when some of the crew came over and helped install the hoist. I have since removed the PVC part and replaced the rope that holds the top with plastic coated cable since it does not stretch. The stretch in the rope was an issue. Total I am in the hoist for under $100.00 not including pizza for the install crew.
https://www.s2ki.com/forums/index.php?showt...&#entry15575497
dammitjim's Avatar
One person hardtop removal w/o a hoist is fairly straightforward in a Miata if you don't mind stepping on the seats. Dunno if this translates to an S2k:
1. Unbolt hardtop
2. Climb into the car with one foot on each seat.
3. Grab the hardtop on each side
4. Stand up with the top over your head and walk out of the car.
Old Sep 8, 2009 | 09:47 PM
DanielZan's Avatar
Can you do that? Can you put the hardtop on top without uninstalling the soft top?
Old Sep 8, 2009 | 10:14 PM
21k's Avatar
21k
yes, the hardtop fits over the folded soft top.
Old Sep 8, 2009 | 11:53 PM
NNY S2k's Avatar
You can put the top on, or take it off, in less than a minute with a helping hand.
Old Sep 9, 2009 | 04:53 AM
MurderS2K's Avatar
damn nice to know!!!
Old Sep 9, 2009 | 08:27 PM
#172CR's Avatar
Yes installation and removal is easy and quick, but it is a 2 person job unless you have a hoist. The hoist is convenient but does take a little extra timing lining things up.
Old Sep 11, 2009 | 06:10 AM
FALCO's Avatar
I actually prefer diving with the hardtop and have only had it on/off about five times. I find it stressful to remove and install...it requries two people and I worry about the paint. The actual installation is straightforward.
will williams
Jul 4, 2014 07:10 PM
Nametaek3n
Mar 29, 2007 04:05 PM
BaCkOfF
Nov 1, 2005 05:57 PM
mikegee
Oct 3, 2005 06:14 AM
