zero gas bars left: how many miles?
Old Jun 20, 2005 | 04:04 PM
  #21
Filthy Beast's Avatar
Im never gonna try to find out.....mine gets to a quater of a tank i start looking
for a Chevron station.
Old Jun 20, 2005 | 04:05 PM
  #22
Indecision's Avatar
I wouldn't worry there's at least another 8.92kg of fuel in the catcher tank. j/k
Old Jun 20, 2005 | 07:54 PM
  #23
tritium_pie's Avatar
[QUOTE=FILTHY BEAST,Jun 20 2005, 04:04 PM] Im never gonna try to find out.....mine gets to a quater of a tank i start looking
Old Jun 20, 2005 | 08:05 PM
  #24
revhi's Avatar
No bars left today, filled with 10.4 gallons.
Old Jun 20, 2005 | 09:12 PM
  #25
Planets's Avatar
No idea how far you can go with no bars, but I will tell you this... I've ran out of gas twice in the last few weeks. Replaced stock fuel pump with walbro and the damn float got stuck so my gauge was off and I ran out of gas. Then we attempted to fix it and, as a test, I intentionally ran it all the way down (270miles on a full tank btw), but now it's stuck at a different level
Anyway, both times, the car started sputtering and I was still able to drive around for like another 20 minutes or so after that. I also noticed that when you are running out, the car won't let you vtec, and you may get a "random multiple cylinder misfire" obdii code Damn float
Old Jun 20, 2005 | 09:13 PM
  #26
koala's Avatar
The gas gauge is highly inaccurate, so when it goes to 0 bars (or the light comes on) you could have anywhere from 2 to 4 gallons left in the tank.
20 to 60 miles, in that area. Generally, it's just a good idea to fill up when you do see the light come on.
Old Jun 20, 2005 | 09:22 PM
  #27
Tyler N's Avatar
I'd say this is pretty accurate, considering it's a 13.4 gallon tank IIRC and when I hit 0 bars and fill up it usually takes about 10.5 gallons to top it off...
Old Jun 20, 2005 | 09:27 PM
  #28
S2000Patrick's Avatar
Originally Posted by tritium_pie,Jun 20 2005, 07:54 PM
...forget rolling around with 1 or 0 bars on the gas gauge... it's much easier to bring the car to the fuel than it is to bring the fuel to the car... on top of the previously mentioned issue of sucking gunk from the bottom of the tank up to the fuel filter...
Very smart thinking. I totally agree, I never run the tank down below 3 bars without filling.
Old Jun 20, 2005 | 09:31 PM
  #29
koala's Avatar
Your performance and gas mileage will both improve if you run it a bit lower though. 13.4 gallons of gasoline at 72 F weighs approximately 83 lbs. So if you have 5 gallons left, you've dropped to about 31 lbs of gas. 50 lbs can definitely be felt in the corners. Plus it's being shed off the drivers side, helping to balance the car's weight better.
Old Jun 20, 2005 | 11:03 PM
  #30
Eluded's Avatar
mine has about 3 gallons when the last bar goes.
