02-03 ECU in 00-01 S2K????????
I was wondering....can the ECU's be switched as easy as swapping batteries? And to get the same gains is there any else that needs to be done other then switching the too???? Please help.
No the ECU's will have to be reprogramed. If i understand correctly you car should start but it will go into limp mode. You the need to head straight to a dealer where they will reprogram the ECU to correctly accept the key u have. But when i looked into doing it there were gonna charge quite a bit to do it.
hmmm....after they reprogram my keys to work with the ecu...will my keys work with my old ecu anymore? in other words...do they program the keys to match the ecu or the ecu to match the keys...
