03 ap1 weird engine noise NEED help!
Old Oct 18, 2008 | 06:00 PM
Naboost's Avatar
Default 03 ap1 weird engine noise NEED help!
was driving the car today and punched the car from first through 2nd gears and then this noise pops up. When i press on the gas the noise stops but once i let off the gas the car starts making this noise.
here's a video i took of the noise.
http://www.youtube.com/watch?v=5AVetPbt0rk
any professional help is appreciated
Old Oct 18, 2008 | 09:50 PM
G's Avatar
G
wow, that sounds bad, I wish I could help and am curious to hear what it is.
Old Oct 18, 2008 | 09:57 PM
JDMQuip's Avatar
That sounds horrible. Good luck man.
Just curious but is there adequate oil in your engine?
Old Oct 18, 2008 | 10:19 PM
learning03's Avatar
Does the noise go away when you press the clutch down to the floor?
Old Oct 18, 2008 | 10:47 PM
Naboost's Avatar
yes the noise goes away when i press the clutch on the floor
Old Oct 18, 2008 | 10:50 PM
Naboost's Avatar
oh yeah and the car only has 17k on the car and yes i have adequate oil not time to change the oil for another 1500 miles unless the honda dealer shp didn't put enough. But there was no check engine light nor was their a maintai
nance
Old Oct 18, 2008 | 11:45 PM
learning03's Avatar
To me it sounds like a clutch disk problem, maybe a spring broke off or something.How does the transmission feel?Shifts smoothly? Also if you cruising and you engage clutch the noise goes away as well?
Old Oct 19, 2008 | 05:44 AM
Nick.'s Avatar
nance
dont depend on them, check your oil!
Old Oct 19, 2008 | 07:48 AM
Naboost's Avatar
also the clutch started to vibrate when i'm not pressing on the clutch
Old Oct 19, 2008 | 07:53 AM
HonCBRf2's Avatar
Sounds as if you answered your own question, pull the tranny to inspect the clutch....
