03 ECU in an 00 AP1?
Old May 18, 2009 | 11:21 AM
kchandra's Avatar
Default 03 ECU in an 00 AP1?
I found an 03 ECU which from what I am reading on here had the most aggressive factory tuning for the AP1's - Is it a plug and play to put into my AP1 or will I have issues with the immobilizer?
Thanks!
Old May 18, 2009 | 12:41 PM
Stratocaster's Avatar
Yes. A dealer will need to reprogram it for you.
Old May 18, 2009 | 01:00 PM
kchandra's Avatar
Thanks, Rick. You are my savior today!
Old May 18, 2009 | 03:08 PM
IlleztImportz's Avatar
does this count for all '00-'01 ecu swaps from '02-'03? do you HAVE to go to the dealer?
Old May 18, 2009 | 03:12 PM
Yes. In fact, if you want to change the ECU for any reason, a dealer will have to reprogram your keys into the ECU. Or it will not start.
Old May 18, 2009 | 03:29 PM
AP1FTW's Avatar
unless of course u get a key with the ECU u purchased
Old May 19, 2009 | 10:47 AM
i see...thanks. was thinking about swapping out my01 ecu for an '02-'03. would they question on how or why you want to swap them out?
Old May 19, 2009 | 10:51 AM
ACutally that will not work either. The receiver is part of the system and it needs to go too. So you would need the ECU, Key, Key Cylinder and immobilizer receiver.
Old May 19, 2009 | 12:47 PM
deathsled's Avatar
You could also bypass the immobilizer, but then you have to deal with a check engine light and the fact that your car could be easily stolen....
Old May 19, 2009 | 05:52 PM
pdenton's Avatar
you're probably looking at 1.5 hrs of labor from your dealer. and yes sadly only the dealer will be able to do it
