03 s2k
hey guys wats up,hope u can help me find my problem,my 03 s2k has an overheating problem,it all started 3 weeks ago when i tried to turn my heater on, heater wouldnt work so i went on the forums here to try and solve that. I did solve the problom by just opening the hood and moving the little lever to hot,its next to the hose in the firewall,and bam my heater worked but it takes awhile for the heat to come out inside. After i did that is when my overheating problem started. All out through summer i used the a/c full blast and never overheated, can anybody help me out ?
the coolant level is good,ive had it for 4mo and i dnt know when was the last time they changed the coolant,in the summer with a/c full blast it never overheated
Is it possible that the heater core had no coolant in it and when you opened that "hot" lever (which I didn't know about) you introduced air into the coolant system? I would follow the coolant bleeding procedure to try to bleed any potential air pockets out of the coolant system. I believe Billman or someone posted a DIY on how to bleed the coolant lines.
