03s2k
i did a valve adjustment on my 03 s2k came out good,i checked compression and its good,but i still have a problem,when i start my car i usually let it idle 5min before i drive it,well when i drive it lets say 1mil or 2 when i come to a stop it dies, it does that sometimes and sometimes it doesnt. They told me to do a valve adjustment and clean my map sensor and i did and still does the same thing, can anybody help me out id really apreciate it, thanx for the help on my overheating problem i think i got that fixed i think.
We'll, if there was truly just air in your system and you've flushed it, and are no longer overheating than I think you're probably fine. But if you continue to overheat its something to look into.
The idle relearn helps initially, but is not completely necessary. Yes, not doing it may cause a stall or two when you initially start driving, but the car will eventually learn over a short while of driving.
The op just recently had a cylinder misfire that I'm not sure was ever resolved. I remembered him from his "all caps" typing style. He did a comp test but never posted the numbers, so could be a lot of things.
clio
Dec 5, 2014 05:30 PM
