03 stalls and stutter after rev down
#21
It's a combination of things that fix the idle, it's never just one thing. Although there can be a main culprit.
#22
Hey, I was wondering if the shaft in the iacv have to be positioned right with the motor for it to work properly? seems like you can get it backwards becuase the notches in the motor seems like theyre identical. or it doesnt matter? Is the magnet suppose to be up or down?
#23
Update. I got my valves adjusted, replaced plugs, swapped iacv with a known good one, guess what its still happening! Idle got better it would only stall sometimes but the idle still drops very low. I also get the kangaroo 1st gear hesitation. Did a compression test and got 220, 220, 200, 200. Cylinder 3 though had fluntuation of initial crank of 60-80psi but the rest were consistent at 80psi.My mechanics guess was worn a valve guide. Im still going to swap injectors and see if that does anything. FML
#24
#25
#26
#27
Seems like you've done everything we would have suggested you do.
Can you confirm HOW exactly you reset the ECU? Did you do the entire idle re-learn process afterwards, without touching the gas?
Here's the right way to do it:
https://www.s2ki.com/s2000/index.php...&f=22&t=549159
Pay attention to the last step, and "DO NOT give the car gas, as it makes it more difficult for the ECU to 'relearn'"
Confirm?
Confirm?
#28
Confirm?
Confirm?
The battery was disconnected from doing the valve adjustment, compression test and plugs changed. Started the car and left it on for 15 minutes till the car is fully warmed up at 3 bars.
#30
okay so i just did the idle relearn again taking the 7.5a out for 2 minutes and put it back in. started the car untill its warmped up at 3 bars. left the car on for at least 15 minutes and gave it a few revs. Still stalls. if i dont touch the gas it idles "okay" with the shaky vibration. Also got a poof after revs and dies. Going to swap the injectors and see what happens
FML.
https://youtu.be/KnhSLB1BuLI
FML.
