06+ DBW throttle wire adjustment
Old Sep 23, 2006 | 07:46 AM
  #21
ottokrat's Avatar
Originally Posted by Dave-ROR,Sep 22 2006, 06:15 PM
The cable DOES NOT connect to the TPS. The TPS reads the position of the throttle plate, it does not read the position of the pedal. In the S2K the cable connects to a accelerator position sensor.
Yes, when I wrote throttle position sensor, I meant the throttle pedal position sensor, though I didn't know the technical name for it.
Old Nov 15, 2007 | 07:57 AM
  #22
unethikl's Avatar
hi guys, i bought a used 06 few months back, and now im confused.
can somebody post a real picture of 06 DBW and/or DBC please??
thank you !
edit.
omg... i forgot if i have an 06 or an 05....
so then 05 is cable driven correct? which makes me qualify for aem ems out there?
thanks again
Old Nov 15, 2007 | 10:17 AM
  #23
TJF's Avatar
TJF
My .02
I wouldnt take the slack out. I know that in other cars I have worked on, the slack is there because of heat expansion and contraction as well as engine torquing in relation to the body and thereby the wire.
Almost every car I have worked on, whether it be carbuerated or fuel injected, has called for 1/8 to 1/4 inch of play in the cable.
Honestly, you arent gaining anything form the adjustment. People complain about non-responsive DBW because it takes the electronics a split second to translate your right foot movement into the throttle body butterfly opening. Changing the cable adjustment doent change that at all. All you are doing is changing the point at which the pedal engages... which is not curing DBW's inherent electronic delay.
Old Nov 15, 2007 | 12:11 PM
  #24
FISH22's Avatar
LOL.
Old Nov 15, 2007 | 08:25 PM
  #25
unethikl's Avatar
yeah i know
i have 2005
i have no idea why i thought i had an 06...
memories these days...
Old Nov 15, 2007 | 08:53 PM
  #26
Errrrk's Avatar
He is not saying it cures electronic throttle lag(which I don't think the s2000 exhibits). But there is a little play in the throttle before it actually does something. I don't think giving it less slack is going to hurt anything and it will definitely help the feel of the throttle.
And some manufacturers program in some DBW lag on their cars to keep the owners from beating on them and so they operate "smoother". One of my VWs had horrible lag, but after I chipped it the lag was gone.
Old Jun 21, 2015 | 12:19 PM
  #27
Clish's Avatar
can someone reupload the picture in the first post?
Old Jun 21, 2015 | 04:59 PM
  #28
Car Analogy's Avatar
If you've ever adjusted a brake cable on a bicycle, you'll know what to do here once you get the cover off.
Old Jun 22, 2015 | 10:43 AM
  #29
shind3's Avatar
Old Jun 30, 2016 | 08:10 AM
  #30
andrewhake's Avatar
Just for the record since I took a picture of the adjustment procedure for the 06+ for a different thread:
The spec for the amount of freeplay for the 06+ cable is much more than the 4-6mm of the earlier models, it is 15-18mm. So don't go taking all the slack out of your 06+ throttle cables please. Also just buy the damn service manual already.
