1 to 2 grind!
Old Sep 24, 2004 | 11:16 AM
B SweepeR B6's Avatar
Default 1 to 2 grind!
ok guys, i have an 03 s2k and first to second will grind maybe two times a day and i mean GRIND THE UP! not a reg. grind i have heard. more like metal totally getting ed up. whats the reason for this? i know the 00 and/or the 01 had a recall on this but an 03 should have been fixed and was from waht i know. what can cause this LOUDD ass grind? thanks.
Old Sep 24, 2004 | 11:48 AM
FO2K's Avatar
Sounds like your 2nd gear synchros may be shot.
If you are in nuetral, clutch out, engine running and put the clutch in and put it in 2ng, does it grind then?
Old Sep 24, 2004 | 12:48 PM
p0pe's Avatar
[QUOTE=B SweepeR B6,Sep 24 2004, 02:16 PM] ok guys, i have an 03 s2k and first to second will grind maybe two times a day and i mean GRIND THE UP! not a reg. grind i have heard.
Old Sep 24, 2004 | 01:14 PM
only 2 weeks and ever since i bought it. it has only about 6,700 miles. i didn't get your instructions. sorry.
Old Sep 24, 2004 | 02:11 PM
Gernby's Avatar
Former Sponsor
Sounds like my car! I had about 2~3 grinds per day for the 1st few thousand miles of ownership (new). I took it to the dealer, but they couldn't reproduce it. Of course, they didn't rev it up, or shift quickly either.
I went through many different tranny lubes, which some helped, and others didn't. The best fluid I have found is GM Synchromesh Friction Modified (not the regular GM Synchromesh). I don't ever grind into 2nd now, but I make sure I keep my oil fresh. Before I found GMSFM, I was changing my oil every 3K miles, which helped a lot. Now I'm only changing it every 7K or so.
While trying different oils, I also adjusted my clutch pedal. My clutch pedal had excessive play at the beginning of the stroke that caused the engagement point to be very close to the floor. Reducing the free play allowed me to get the clutch completely disengaged during a quick shift. This reduced my grinding quite a bit, but didn't eliminate it. You should also teach yourself to shift from 1st to 2nd more slowly and precisely. This box doesn't forgive a sloppy shift.
Old Sep 24, 2004 | 02:41 PM
hpark's Avatar
change the diff and tranny fluid as suggested (there are other threads on this)
try double clutch shifting when car is cold
try shifting at higher RPM's or different RPM's.....
Old Sep 24, 2004 | 03:19 PM
Gernby's Avatar
Former Sponsor
Are you one of the authors of "Fast and Furious"? There is no such thing as double clutching on up-shifts, and differential oil has NOTHING to do with it! Grinding into 2nd gear tends to happen most when the tranny oil is too hot.
Old Sep 24, 2004 | 03:45 PM
xviper's Avatar
Also, check and see how your clutch fluid is doing. Maybe a change there is also in order. Do you put the clutch all the way to the floor when you shift and are you being very calculated about where you pull the shifter when going into second?
Old Sep 24, 2004 | 05:04 PM
do you mean as in puttin the shifter into 2nd or somewhat missing 2nd adn gettin it into lets say btw the 2nd and 4th gear? like misshifting it in a way is what you mean? i have a sligggggggght feeling that maybe i dont step on the clutch all the way when it grinds once in a while and put it into 2nd. i am not syaing that is the reason but i will pay more attention to it and see if that MIGHT be it which i highly doubt it tho.
Old Sep 24, 2004 | 06:02 PM
forsaken's Avatar
There is a long thread about this problem a few months ago. I have the same problem. I have found a lot of people fixing this by switching to "GM Synchromesh Friction Modified" tranny oil. NOT the orginal "GM Synchromsh".
Thanks to gernby for suggesting this first on this forums . This tranny oil fixed a lot of s2k grinds and nsx grinds. Fluid has also been certified by RoadRage for having the right contents on it.
Thats the cheapest change you can do. I suggest trying this first, if it fails then u can try other things like, synchro rebuild, etc...
