15w-30 performance oil?
10W30 ----- 15W30. You live in Florida. What difference does it make. Once you get the thing warmed up, both oils will be 30 wt. The "W" applies to the first number which is its viscosity for cold weather cranking (or cold starts). If you're worried about the oil under hot weather high performance conditions, you should be more concerned about the 2nd number.
These oil threads always brings out the "best" in people. Pretty soon, the discussion progresses to everything BUT oil.
Crest makes at least a dozen, maybe more, different "kinds" of toothpaste and if you read the LABELS, you'll see there's one for white teeth, one for tartar fighting, another for fresh breath, etc. I wonder if they just push the same stuff into ALL the tubes. For sure, next month, I want the "high performance" tooth paste!
sorry secret i must not be as smart as you. maybe you can teach me and i can learn how to be a total di*k too. i'm sorry i'm only 18 and i don't know everything yet like you. thats what i thought this site was for! for people like me who have questions about there s2000's that they would like to know and don't know the anwser.i didn't know i had to know everything to post something. next time i'll make sure i already know the question to the answer before i ask it.
Originally posted by vapors2k
that may be true but the additives responsible for the multiple weight break down over time and milage which results in a not so 10w30 formula.
Originally posted by gernby
Hence, a 3000 mile oil change interval.
Originally posted by wc_one
If you drive in hot weather and at high rpm 10W-30 will damage your engine.
Sorry, but I'm with Tugz.
Originally posted by BlueS2000Boy
well i spoke with honda and they told me it would be ok to put 15w-30 in my car because of ther high temps in fl. it wouldn't hurt at all. they told me if i drive my car hard everyday i should go ahead and do it.
SO, lets see if this will make sence to you...
if you use a 15W30 oil this is what will happen.
Under normal cold start-up, because the oil is a 15 weight oppose to a 10 weight, it will take a fraction of a second longer for oil to travel to engine parts. Havent you heard the saying? "Almost all of the wear in an engine occurs during startup"...what u want is to have the oil get to those vital engine parts asap after startup...a 15W30 will not help in that..10W30 is better.
As for high RPM's and high temperatures, like I said before, there is NO difference between the two 15W30 and 10W30. They WILL provide the SAME protection under normal driving conditions...
SO...this is what im saying, do NOT use 15W30, first of all it is not the reccomended oil for our cars and secondly, it will not provide the proper lubrication during cold startup....even on the warmest mornings...
OH and for that dealer who reccomended 5W20 oil...
...dont make me go there...peace
Kids. You try to help them out and they just question your answers. Notice that he said his father's 911 says to use 10W-30, but Porsche recommends using 15W-30. I think he just wanted to use it because it the bottle of oil stated high performance . I think we should all be aware of this car when he sells it. Buyer beware!!!!
sorry i got off on the wrong foot. it was my mistake for blowing up. my excuse is that i didn't have breakfast or lunch. in any case, 15W30 will probably end up slowing you down. Your S2000 will run perfectly fine using 10W30. Certainly if there was a problem with it, you could take it up with the manufacturer as it is a factory recommendation to use 10W30. trust us when we say, 15W30 is overkill. good luck.
