1st gear and Reverse
Old Jan 16, 2014 | 07:56 AM
ManOnFire75's Avatar
Default 1st gear and Reverse
Hey All,
this problem just arose recently where 1st gear is very difficult to get in gear and reverse is almost impossible. I am the 2nd owner of my s2000 and have been checking my fluids but I have a feeling that, I need to change the tranny oil fluid. I have no clutch problems (slipping,grinding etc). Matter of fact once I start rolling 2-6 are fine to shift into. Its just 1st and reverse because Im stopped and not moving. I am hoping it just needs tranny oil opposed to people saying I need to change the clutch/tranny when I know both of those are fine.
Thanks
Old Jan 16, 2014 | 09:07 AM
iamxpl's Avatar
chances are you just need to change the fluid. when was the last time you did it? it wouldnt hurt changing out the clutch fluid as well.
Old Jan 16, 2014 | 02:08 PM
INDYMAC's Avatar
I think there is a TSB for this. I believe I saw it in the shifter re-grease DIY thread.
Old Jan 16, 2014 | 04:23 PM
Utah S2K's Avatar
This is the correct answer.
Utah
Old Jan 17, 2014 | 03:58 AM
iamxpl's Avatar
this was gonna be my next suggestion. lol
Old Jan 17, 2014 | 01:22 PM
Gotpepsi's Avatar
Check your clutch fluid and see if the clutch master cylinder is leaking. Low clutch fluid may be related to your problem.
Old Jan 18, 2014 | 05:24 PM
Alright sorry for the late write up.
It was the tranny fluid, it was pretty old now i can slide into the gears with 2 fingers pushing the shifter. As for the Clutch peddle, my dummy self didnt check it and it got low so air got into the system. Me and a buddy bled it and now my clutch peddle is uber stiff which is great. Now the car shifts as smooth as a automatic.
Thanks for the info fellas!
Old Jan 18, 2014 | 07:49 PM
jkelley's Avatar
I'm glad you were able to sort this issue out.
I think I've heard of a similar issue in a recent thread that was a result of "burrs" forming on the syncros in the transmission as aresult of skip shifting. The issue was also resolved from yet another one of Billman250's awesome, simple fixes by shifting hard in a very specific sequence to remove the hard "burr" edges on the syncros.
Just thought I would share
Old Jan 19, 2014 | 01:11 AM
Gotpepsi's Avatar
Clutch fluid in the reservoir will not simply get low for a reason. There has to be a leak for the fluid to escape. I would start by checking the clutch master cylinder under your drivers foot well. Check the carpet for staining and the CMC itself for a leak. Its very common.
s2k tony
Jul 20, 2015 01:35 PM
fallen612
Nov 2, 2009 12:25 PM
Legal Bill
Sep 18, 2007 01:34 PM
cosplayerkyo
Jan 2, 2006 11:14 AM
MattG
Sep 24, 2004 07:17 PM
