Clutch Problem.
Old Jul 20, 2015 | 01:11 AM
s2k tony's Avatar
Default Clutch Problem.
I have a 2004 S2000 and yesterday it was quite stuff to get into gear and this morning it was a struggle to get it into gear. I found that once I was driving it became easier to change gear. Whenever I am stationary it's hard to get it in gear. Do I need a new clutch? If so how much am I looking at paying?
Old Jul 20, 2015 | 04:07 AM
Slowcrash_101's Avatar
Check other cheaper stuff first, check the master and slave cylinders. Clutch fluid level, bleed the line, change tranny fluid. See if that helps.
Old Jul 20, 2015 | 04:40 AM
s2k tony's Avatar
The clutch fluid level is fine and I had all new fluid put in about 6 months ago. I will check the cylinders tonight. Thanks.
Old Jul 20, 2015 | 04:57 AM
How about mounts motor diff transmission.
Old Jul 20, 2015 | 05:40 AM
windhund116's Avatar
Change tranny oil recently?
Old Jul 20, 2015 | 05:44 AM
s2k tony's Avatar
The tranny oil was changed at the same time as the clutch fluid.
Old Jul 20, 2015 | 06:41 AM
Did the tranny oil change -> more difficult shifting?
Old Jul 20, 2015 | 07:33 AM
Gotpepsi's Avatar
Sometimes the clutch master cylinder could be leaking and you'll lose all your fluid. I would double check your master cylinder. Fluid could be gone in six months, easy.
Old Jul 20, 2015 | 11:54 AM
s2k tony's Avatar
I've looked at the clutch master cylinder and it looks it has been leaking. I topped it back up with fluid and it did make a difference. I've cleaned it all up so I can see where the leak is coming from then but what I need to fix it. I hope that will solve the problem. Thanks for everyone's help.
Old Jul 20, 2015 | 12:15 PM
Gotpepsi's Avatar
The master cylinder is leaking inside your cabin where the cylinder gets pushed in. You have to replace the unit, it's very common in s2000s.
