2004 ap2
Old Jun 28, 2018 | 07:30 AM
Chuck S's Avatar
No need to race anyone. Punch it on the next on ramp when no one is around and you'll find the rev limiter soon enough. Scared the crap out of me the first time.
The rev limiter won't save your engine if you miss a gear and hit one too low. 5th to 4th and hitting 2d will ruin your day.
-- Chuck
Old Jun 28, 2018 | 07:48 AM
kjonesy203's Avatar
-- Chuck
definitely wouldnt check while racing. But definitely plan on doing it on an empty road til it cuts. Always a crazy feeling when that happens lol
Old Jun 28, 2018 | 10:04 AM
twohoos's Avatar
This is an interesting one! Wonder if he's got an F20C stroker? Maybe the previous owner threw a rod and rebuilt an "F22" from an F20 block?
Before redlining it, pull the kick panel and see whether it's an OEM ECU. You might even be able to tell if it's '00-'03 or '04-'05 (look for a part number). If it's aftermarket, all bets are off as far as what's in that motor.
Oh, and the trans should have a VIN plate visible from under the car, so you can check to see if it matches your car.
Old Jun 28, 2018 | 11:04 AM
hirev's Avatar
where does your tack redline? 9000 would be an ap1, 8200 is an ap2
doubt the guy swaped engines and left the tack alone/dash alone.
more photos of the car might help? interesting issue.
Old Jun 28, 2018 | 11:47 AM
kjonesy203's Avatar
tack redlines at 8k. Its an ap2 cluster ill drop more pics.
Old Jun 28, 2018 | 11:48 AM
kjonesy203's Avatar
i will look at the ecu when i get home and ill check the trans for a matching vin number too
Old Jun 28, 2018 | 01:03 PM
kjonesy203's Avatar
Dont know the difference between ap1 an ap2 but had this pic in my photos
Old Jun 28, 2018 | 01:50 PM
DanielB's Avatar
You don't have to be moving to find the redline. Probably safer to do it parked.
Old Jun 28, 2018 | 02:41 PM
kjonesy203's Avatar
cant i check my ecu with a obd2 scanner as well?
Old Jun 28, 2018 | 03:33 PM
kjonesy203's Avatar
37820-PCX-A01
ap1 ecu
