2005 s2000
Old Jan 17, 2019 | 03:51 PM
B serious's Avatar
No, the valet key doesn't slow the car down to 25mph and give it no power. It just doesn't allow the trunk or glove box to be unlocked.
OP. Is there a check engine light on? Does the check engine light work?
Why not just have it inspected. There are about a billion reasons why this could be happening. Nobody on here is going to be able to give you an answer with the question you've asked.
Old Jan 18, 2019 | 11:22 AM
Boosted04S2K's Avatar
Originally Posted by Adrian Hernandez
Yes. I can go up to 3rd or 4th but no power. I bought it without driving it. I changed the timing chain tensioner because it was leaking oil. I should of driven first lol.
Just to verify, did you drive it before you changed the tensioner? One thing to check for that can limit the engine that much would be a blocked exhaust system. Where did you get it? Did it sit for long?
Old Jan 18, 2019 | 01:49 PM
noodels's Avatar
Brakes seized on !!
Old Jan 20, 2019 | 05:21 PM
Alexs '05's Avatar
What area of Miami? Have some friends down there who are very knowledgeable with their S2000's and can probably point you in the right direction to figure this out if you haven't already.
Old Jan 21, 2019 | 09:56 AM
soulicious's Avatar
Just curious, are you using a standalone ECM (like AEM EMS)?
Old Jan 21, 2019 | 11:24 AM
s2000Junky's Avatar
Sounds like the car has triggered a cel/fault. Some of these will limit the rpms to about 3k depending on what the fault is. You need to read that code and figure out what it is. But resetting the ecu/pulling batt terminal would/should temporarily fix this, until the cel gets triggered again. You need to figure out what the cel is before you possibly cause engine damage if there isn't already.
Old Jan 21, 2019 | 09:20 PM
RolanTHUNDER's Avatar
What if they push the button inside the middle glove box, wouldn't that still open the trunk (or would that button be rendered unusable by the valet key in the ignition...?)?
Just curious.
OP: reset your ECU and take it from there. If the car sat unused for a long time you should run some fuel system cleaner as well.
Old Jan 22, 2019 | 04:26 AM
Chuck S's Avatar
Lock the center compartment if you want to keep the valet out of your trunk. The valet key will not open it (or the trunk). I never got this key with my used car. But don't let valets drive it anyway.
-- Chuck
Old Jan 22, 2019 | 10:00 PM
-- Chuck
Yeah that's what I figured. Lock the cubby to prevent access to the button inside. No valets allowed to drive my car and I do have the valet key, full 3 key set in fact with my '00
Steha
59
Nov 27, 2009 09:48 AM
Billman250
30
Dec 9, 2005 04:41 AM
markS2kcU
Sep 25, 2005 12:34 PM
Road Rash
Aug 26, 2005 06:36 PM
Tifosi Red
Apr 3, 2002 05:03 AM
