2006-2007 Radiator Fan Switch. HELP
Old Sep 11, 2008 | 08:19 PM
9kFever's Avatar
Default 2006-2007 Radiator Fan Switch. HELP
So I am parting out my car and thought I would hook a friend up with my Koyo Radiator. His car is a 2007. So we swap radiators only to find out now that the fan switches are different. I read this thread and saw 2qyk4u saying that you cant just splice on the connectors (basically we would swap). Can anyone confirm this? The fan switch in the koyo is a Mugen.
https://www.s2ki.com/forums/index.php?showt...&#entry11012301
ARGH!
Old Sep 12, 2008 | 03:56 PM
9kFever's Avatar
Somebody please help
Old Sep 12, 2008 | 07:33 PM
coquinn's Avatar
2QYK4U is correct, the Mugen switch will not work on an AP2, you will need to have a bung welded and threaded for the AP2 fan switch.
Old Sep 12, 2008 | 07:39 PM
2QYK4U's Avatar
I do not believe this type of mod is as simple as simply having a different bung welded in a radiator:
1. The MY06+ S2000 uses a fan switch that is smaller than PY S2000s.
2. The MY06+ S2000 has two temperature control sensors--one at the radiator and one at the intake manifold.
3. If you change either one of these sensors there is a -chance- that you could send false signals to the ECU and who knows what happens from there.
If you want to use an aftermarket radiator on an MY06+ S2000, you can simply have a smaller bung welded into that radiator and use the OEM fan switch. At this point I would advise against not using the MY06+ fan switch and sensor going into the intake manifold.
Old Sep 12, 2008 | 08:02 PM
coquinn's Avatar
I guess I didn't clarify what I meant. I meant he would need to have a bung welded and threaded on the Koyo radiator to retain use of the OEM AP2 (MY06+) fan switch.
Thanks for clearing it up though.
Old Sep 12, 2008 | 08:04 PM
2QYK4U's Avatar
Correct. It is probably best to not refer to *some* MY06+ parts as AP2 because they are simply different. Honda probably should have classified the MY06+ as an AP3 because of the significant changes.
Old Sep 12, 2008 | 10:49 PM
9kFever's Avatar
Ok so what about for me? Could I run and ap3 (lol) radiator on an ap1 and just splice an ap3 connector on to my harness and run the ap3 fan switch.
Old Sep 13, 2008 | 06:17 AM
2QYK4U's Avatar
I think that would work.
Old Sep 13, 2008 | 11:31 AM
negcamber's Avatar
You might be breaking new ground with that too.
Phil...did you end up getting your Mugen fan switch to work with your MY06 ecu?
Old Sep 13, 2008 | 01:25 PM
jcmotorsports's Avatar
I tried to spice an AP1 fan switch to an 06 harness. It does not work. The CEL comes on. You need to use the 06 temperature sensor. Like 2qyk4u said, you need to have a bung welded for the MY06 sensor.
aphex4000
May 28, 2015 03:44 PM
Wannabes2k2k11
May 19, 2015 08:43 AM
Prestonubc22
Jun 22, 2012 06:55 PM
jellybbs
Nov 17, 2006 12:38 PM
CrAzYNeSs
Jun 2, 2006 02:38 PM
