2006 s2k Gear problems
Old Jun 8, 2006 | 10:45 AM
wgp_hoppa's Avatar
Default 2006 s2k Gear problems
About 2 weeks ago i bought my new 2006 s2k and now im having troubles with 3rd and 5th gear. its a little harder to shift into 3rd and 5th gear. and when i do shift it into gear, i feel like its scratching up against something...has anyone had this problem with their 2k?
Old Jun 8, 2006 | 11:27 AM
wgp_hoppa's Avatar
bump
Old Jun 8, 2006 | 11:58 AM
RadioZero's Avatar
since both of those shift lever throws are similar, try changing the way you're holding your knob and see if that helps. sounds gay but see if its your shifting technique before assuming its the tranny.
Old Jun 8, 2006 | 12:03 PM
RedChili's Avatar
Usually 3rd and 5th gear are easy. First and second are a little tight when cold.
Old Jun 8, 2006 | 12:11 PM
ucisgreatone's Avatar
i get a *clunk* noise shifting into first at a stop... happens occasionally
Old Jun 8, 2006 | 12:21 PM
Fat Free's Avatar
when mine is cold 2, 3, 4 are tight...but silky when warmed up.
Old Jun 8, 2006 | 12:46 PM
wgp_hoppa's Avatar
hmm i tired different ways of holdin the shift knob. out of the...lets say 10 times that i shift into 3rd of 5th it makes thas scratching feeling 8 outta 10 times...
Old Jun 8, 2006 | 01:01 PM
mikey k's Avatar
Try slowing the gear change down slightly. You might be too quick for the delay valve in the clutch cylinder.
Also take it back to the dealer and at least register the problem with them now encase it gets worse!
One other thing get some one else to drive (other than dealer) and see if they can spot it
Old Jun 8, 2006 | 01:34 PM
IheartS2ks's Avatar
same. plus i also get the 1st gear clunk.
sometimes i'll grind 2nd when the car is cold, but that has to do with driver error (me being lazy and not pushing the clutch all the way down.)
Old Jun 8, 2006 | 01:45 PM
diabolus2k's Avatar
2nd and 3rd are always notchy for me when it's cold.. but after switching the tranny fluid to synchromesh it's much better, and becomes buttery smooth once the tranny is warm
