2nd Gear TSB 05-009
Old 11-02-2006, 09:19 AM
xMACx's Avatar
with Ken above.
Mine popped out of 2nd decelerating and it happened quite often (typically when at high rpms).
It hasn't happened since it was repaired and it drives great.
Old 11-03-2006, 12:49 AM
i2ichal2d's Avatar
what dealer did u SoCal guys go to?
Old 11-03-2006, 11:41 AM
chuhsi's Avatar
I'm trying to get mine done at norm reeves because it's close to home.
do NOT go to norm reeves. way too crowded and poor service. i can't even get myself to explain how bad it is.
Old 11-03-2006, 03:49 PM
S2KenC's Avatar
Honda World of Wesminster perfomed the TSB service for me. If you go to Honda World, make absolutely sure that you ask for Andy Tran. Have him test drive your car and if he is able to replicate the problem, he'll fix it for you. Honda World had my car for 4 days because once they had the transmission open, they also had to replace the input shaft seal because it was also leaking. Andy also provided me with a rental car while my car was down. All in all, the service was excellent.
Old 11-03-2006, 09:50 PM
x s2k x's Avatar
What happens if they cannot replicate the problem on the spot? Does this mean that I cannot get it replaced until something bad happens to me while driving?
I also checked my vin# and mine falls under the TSB listing. What should I do?
Thanks,
Rod
Old 11-04-2006, 01:19 PM
energy88's Avatar
I would think if your car is in the VIN number range cited by the TSB, Honda would perform the TSB without you having to 'prove' there is a defect. I would also think that this could be considered somewhat of a safety hazard since a car suddenly popping out of 2nd gear puts a driver in the position of briefly not having full control of the vehicle.
I can see why Honda might balk at performing the TSB on vehicles outside the VIN range due to the expense. The TSB says 8.2 hours and I would imagine the parts would run $300-400. That makes for at least an $1,100 repair per car and we are talking around 8,000 total U.S. vehicles which implies a total cost pushing $9 million.
Old 11-05-2006, 03:23 PM
s2kVA04's Avatar
I didn't see this TSB listed under the sticky in the library forum... Is there a copy of this TSB online somewhere?
Old 11-05-2006, 06:54 PM
daverx7's Avatar
[QUOTE=energy88,Nov 4 2006, 05:19 PM]I would think if your car is in the VIN number range cited by the TSB, Honda would perform the TSB without you having to 'prove' there is a defect.
Old 11-05-2006, 11:36 PM
S2KenC's Avatar
Here's the TSB if anybody is looking for it:
TSB 05-009
And for me, the dealer needed to replicate the problem before they consider performing the TSB. As daverx7 mentioned, I also videotaped my car popping out of 2nd gear just as a backup in case they were not able to duplicate the problem.
Old 12-29-2006, 05:09 PM
energy88's Avatar
I finally had this TSB performed last week and it sure makes a difference. You don't have to fight the car going into 2nd gear anymore. They used the old parts number Honda MTF as transmission fill, but I can't tell any difference in the unaffected gears (3, 4, 5, 6). Have 500 miles on the car since the TSB and haven't noticed any additional unrelated problems yet that the work may have caused elsewhere. I'm glad that I had it done.
Quick Reply: 2nd Gear TSB 05-009
