3mm headgasket
Old Mar 16, 2009 | 12:39 PM
crave13k's Avatar
Default 3mm headgasket
hey everyone.
so i removed my head to get it inspected for bent valves and since i plan to go turbo in the near future, i bought a 3mm headgasket from cometic. my question is:
will i have any problems running the 3mm headgasket without turbo(na) like any cel's coming on or will the car run ok ? thanks in advance
Old Mar 16, 2009 | 12:45 PM
s2k dre's Avatar
u wont have any problems with running it like that, but ur cam timing with be off and those gaskets have a 50/50 chance of leaking.
Old Mar 16, 2009 | 01:07 PM
DFWs2k's Avatar
your car will be way less powerful
Old Mar 16, 2009 | 02:57 PM
crave13k's Avatar
so i will lose power and the timing will be off. if i perform that sprocket mod where u remove the pin and move the gear clockwise will i then b ok with the timing? so cometic gaskets are no good?
Old Mar 16, 2009 | 04:03 PM
downloader's Avatar
your lowering your cr when you put a thicker head gasket on
Old Mar 16, 2009 | 07:17 PM
TelosHedge's Avatar
you must modify the sprocket for timing to be correct, yes. i have no idea if you can even run the car without doing this. i wouldn't recommend it.
you will lose some power up top for sure, but i drove around like that for a little while and it was no big deal. you have a better than 50/50 chance of it being successful, just take your time on the install and do it correctly.
Ghost_Driver-cr
Apr 1, 2012 08:33 AM
flipnrr
Oct 30, 2007 05:44 AM
dagostino777
Apr 26, 2007 06:00 AM
jbotstein1
Feb 26, 2006 09:55 PM
KiT
Oct 20, 2005 12:04 PM
