5mm wheel spacer require extended studs?
Old Oct 21, 2005 | 01:13 PM
RWD_RCKT's Avatar
Default 5mm wheel spacer require extended studs?
Anybody know? The 5mm H&R wheel spacers for the S are the DRS series which come with studs... but I did not think it was necessary?
I know 15mm BBK people have to use them... but I didn't think 5mm would have to.
Thoughts, comments, bad jokes???
Old Oct 21, 2005 | 02:42 PM
Asura's Avatar
Link?
You going to run those 13" gold wire wheels with a 3" lift?
Old Oct 21, 2005 | 06:10 PM
SIIK2NR's Avatar
5mm spacers will still allow you to use your stock studs. ALTHOUGH...it is recommended that you get the extended ones.
Old Oct 24, 2005 | 07:03 AM
RWD_RCKT's Avatar
Originally Posted by Asura,Oct 21 2005, 02:42 PM
Link?
You need a link for 5mm spacers?
And it's 13" Zenith's... with fast bags... so I can drop it like it's hot (you know... for the b!tches).
Thanks S11K2NR. That was my understanding as well.
Old Oct 24, 2005 | 07:49 AM
Asura's Avatar
All about the 13" Elo screens. Screw Zenith.
I'll just take your spacers. I think I will need 7-10mm.
Drop it like it's Shireen?
Old Oct 24, 2005 | 09:01 AM
Asura's Avatar
Thanks Harry
Old Oct 24, 2005 | 09:05 AM
RWD_RCKT's Avatar
Originally Posted by hecash,Oct 24 2005, 09:00 AM
I use 5mm H&R spacers on the track. I have put in the extended studs on the front but not the rear. I've had them for about 3 years now.
For my clarification, you run the 5mm spacer on the rears too?
Old Oct 24, 2005 | 10:02 AM
RWD_RCKT's Avatar
Thanks Hecash.
t-o_double_d
Jan 7, 2015 12:45 PM
thewhiteknight
Apr 8, 2009 05:38 AM
NA-088
Sep 17, 2007 06:48 AM
Ro_Ja Boy
Apr 8, 2005 08:57 PM
