600 dollars to replace a tct?
Old Jun 16, 2008 | 06:50 PM
skeithr's Avatar
Default 600 dollars to replace a tct?
i went to 3 different mech's today to get price quotes on replacing tct, and every one of them said 7 hrs of labor, something tells me i should never go back to them ever.is there a diy posted somewhere on here or at least the amount of torque to tighten the 10mm bolts back after replacement? ill just do it myself, you know what they say " you cant trust anybody"
Old Jun 16, 2008 | 06:56 PM
S2KPUDDYDAD's Avatar
Those bolt brake easy so be careful It is not a hard job to do at all, as for the tq. setting...just snug them back down but, don't get crazy or snap
Good luck
Old Jun 16, 2008 | 07:17 PM
03silver2000's Avatar
were are you located carolina? If you were near mass I would do it for 200=). No really though its easy just take out the bolts for the old one, I belave you need to take the vtec solenoid out of the way, remove the bolts on the old one, remove the maintenance hole in the side of the block, put the new one in with the pin still in! and pull the pin out from the side with needle nose pliers. after you tighten the bolts tighten the maint. plug and the vtec solenoid and your good to go!
Jordan
Old Jun 16, 2008 | 07:42 PM
triumph87's Avatar
Do it yourself!! it takes less then 20 minutes
https://www.s2ki.com/forums/index.php?showtopic=544760
Old Jun 16, 2008 | 07:44 PM
chino101's Avatar
Those mechanics are either:
A) unfamiliar with the S2000 TCT
B) ripping you off
On Mazda CX-7's engine, TCT replacement involves removing the timing change cover, and a host of other parts in order to get to it; very time consuming. But then again, I still don't see how even that would take 7 hours.
The torque spec for the bolts on the TCT are 9 lb-ft
Old Jun 16, 2008 | 08:40 PM
skeithr's Avatar
B) ripping you off
im sure they are unfamiliar, one even said they would have to take of the chain to do it, the other asked me if i just wanted to change the belt, i just walked away
Old Jun 16, 2008 | 08:45 PM
skeithr's Avatar
silver, i appreciate the offer btw, im in asheville nc, doubt i will have time to run up that way. thanks for the info though. i have a great friend that works on cars, as long as he has the specifics im sure he can do it. thank you all for your response
Old Jun 16, 2008 | 09:42 PM
f23power's Avatar
600 will buy you 4-5 brand new TCTs
-a
robmiller
Dec 31, 2018 03:45 AM
Ivanaguilar
Jul 27, 2017 10:59 PM
nofearofdanger
Nov 2, 2011 07:04 PM
s2konroids
Mar 24, 2011 04:18 PM
AusS2000
May 29, 2005 03:30 PM
