75W-90 vs 75w-110 DIFF fluid
I was just going to ask if anyone here ever tried this stuff:
http://www.redlineoil.com/product.aspx?pid=44&pcid=8
How long have you been running it?
I believe the RLO Shockproof oils have suspended, solid molybdenum in them. One of the beauties of using a torsen diff is you don't have to worry about friction compatibility with clutch materials.
Originally Posted by B0neSt0ck' timestamp='1314003766' post='20900724
Redline Heavy Shockproof. So far I like it.
When it comes to long sweeping corners under acceleration I believe the diff was locking up and causing understeer, and if I lifted it would resort to oversteer. It was worst with 75w90, it got better with 75w110, and I think it is perfect with 75w-140 (all Amsoil severe gear fluids). I hope to have a UOA sample of my 75w140 from this season in the next while. If the UOA looks good I'll keep running it into the future.
technically they should be the same in cold temp operation, but there would be a slight difference in the viscosity index between the two as they warm up, if you are talking about a high quality synthetic fluid the difference would be very small as both would meet the same spec. I wouldnt worry about using 75w110 in extreme cold temps (in fact I have). They will both flow better than the 80w90 fluid that Honda dealers use in our diffs, and still provide better warm temp protection IMO, best of both worlds.
