Old Nov 26, 2006 | 05:06 PM
FOXCONN4's Avatar
Thumbs down ............
Old Nov 26, 2006 | 05:20 PM
90crvtec's Avatar
If your diff is already bad changing the fluid won't help. The symptoms you're describing do sound like a bad diff. When you pulled the drain plug in your differential did you notice any large metal bits stuck to it?
Old Nov 26, 2006 | 05:30 PM
ronnuke's Avatar
Wouldn't the whining continue even after the clutch was depressed if it was the differential?
Maybe noisy clutch?
Or even rear brake calipers sticking, or worn rear brakes ready for replacement.
Are you coincidentally stepping on the break while depressing clutch causing the rear brakes to no longer be just dragging but making full contact with rotors and hence not whining?
Could be a lot of things. But these are all possibilities. HTH
Old Nov 26, 2006 | 05:32 PM
BlownAP's Avatar
dose it happend when your decelerating? leaving the car in gear and clutch out??
Old Nov 26, 2006 | 05:57 PM
chris_barry's Avatar
I had this on my 2000 model diff. All the teeth on the pinion were unwrapping themselves. A bit like when you wind a curtain rope the wrong way.
I would put the car on stands, and run it up with the wheels in the air. Hold a screwdriver with the blade on the diff, and the handle against your ear. This acts as a primative stethescope and allows you to chase the noise.
If it sounds like the diff, disconnect the propshaft from the diff. Best method is to snap free the allen headed fasteners with a quick snap action. You can then spin the wheels by hand and listen again. Disconnecting the propshaft eliminates any gearbox/propshaft noise.
Good luck
Chris.
Old Nov 27, 2006 | 11:14 PM
Have you run the car up while on a hoist and listened to where the noise is coming from? Use the brake gently to load up the driveline.
You are going to have to do some more diagnostic work at your end. My crystal ball is away getting its galactic flux diodes upgraded at the moment.
If the noise pitch to road speed ratio stays the same, irrespective of what gear you are in the problem is either in the differential/rear hubs or the output stage of the transmission.
Keep looking.
Old Nov 28, 2006 | 06:50 AM
Dabutkus's Avatar
Originally Posted by FOXCONN4,Nov 27 2006, 02:11 PM
Any one that can help me?
I'm pretty sure it's your diff man. The same thing happened to me. It seemed about 30-35 mph is when it would start. Usually 4th gear too. It would get louder and louder as the speed increased. I don't remember if it stopped when I pushed in the clutch though. I had almost the same mileage as you do also. I think I was at about 61k.
Good luck!
Old Nov 28, 2006 | 09:27 PM
pastfast125's Avatar
Well, everybody has already givin you quite a few things to try, have you done them yet? I think it would be best to listen to them and try to diagnose the problem rather than randomly replacing parts untill it works. just my .02
Old Nov 29, 2006 | 06:24 AM
SpaZilla's Avatar
im hearing alight whine as well but it doesnt really get higher with the speed, removed all the sound deadining behind the seats byt he fuel pump, im pretty sure im hearing the fuel pump
d4atls
Aug 1, 2014 12:01 PM
speakeasy2009
Oct 31, 2011 03:59 AM
PilotChris
Dec 6, 2010 11:49 AM
erikvanden
Jul 30, 2010 12:13 PM
Red S2000
Dec 1, 2006 11:51 AM
