Odd trans / clutch / rear diff problem?
Old Jul 22, 2014 | 07:13 PM
d4atls's Avatar
Default Odd trans / clutch / rear diff problem?
ok so sometimes when I stop somewhere it's like the clutch isn't disengaging completely and it'll kinda pull a little even in neutral and in reverse the car acts like it's gonna go dead..... Any ideas on where to start? I've owned Honda's and Acura's my whole life but just bought this one and it's a whole different animal.... Someone point me in a general direction please!
Old Jul 22, 2014 | 07:22 PM
96-EJ6's Avatar
Clutch hydraulics...check fluid level and condition...look under the dash where the clutch pedal connects to the actuator rod...follow that rod to the clutch master cylinder on the firewall...if it's leaking replace the master. If every thing there is good jack the car up and inspect the slave cylinder on the transmission for leakage.
My money is on low fluid due to master cylinder leak.
EDIT: Does it only try to die with the clutch depressed?
Old Jul 22, 2014 | 07:24 PM
d4atls's Avatar
Fluid is good, what I don't get is it pulling even in neutral. And why it acts like its gonna die in reverse....
Old Jul 22, 2014 | 07:29 PM
96-EJ6's Avatar
Shifter feels normal? You can select all gears?
Old Jul 22, 2014 | 08:36 PM
d4atls's Avatar
and no for the pedal, only when i'm trying to back up, it's like the ebrake is up or the rear diff is in a bind.
Old Jul 22, 2014 | 09:07 PM
d4atls's Avatar
And yes shifter is normal... all gears are good.
Old Jul 23, 2014 | 09:25 AM
d4atls's Avatar
Any other ideas?
Old Jul 23, 2014 | 12:38 PM
96-EJ6's Avatar
Can you roll the car forward and backward easily in neutral with the engine off or at idle?
Old Aug 1, 2014 | 12:01 PM
d4atls's Avatar
Checking this today, I have it parked in my shop for now......
Bloodred
Nov 1, 2010 12:15 AM
tampaSuzuka
Feb 9, 2010 04:36 PM
epaplia
Oct 20, 2008 10:16 AM
8BALL
Jul 6, 2006 12:43 PM
Amit
Mar 21, 2006 07:54 PM
