about to purchase jap spec ap1 f20c
Old Apr 21, 2010 | 02:40 PM
crank's Avatar
Default about to purchase jap spec ap1 f20c
i am positive it will but just double checking, i found a killer deal on a Complete swap and i am about to go ahead and make the purchase ! did the jap spec s2000's have issues with the oil squirters also ?
Old Apr 21, 2010 | 03:10 PM
crank's Avatar
any input ?
Old Apr 21, 2010 | 03:16 PM
Meshca's Avatar
This isn't a live service center . Call a speed shop that deals with s2000s if you want a quick answer.
I'm not advertising for these guys, nor have I used them before, but http://www.thes2000shop.com/ looks like a place you can call and ask that question.
Old Apr 21, 2010 | 04:16 PM
crank's Avatar
i did a search and it seems that there is no vtec oil pressure sensor on the f20c, i do have my old harness and all sensors though
Old Apr 21, 2010 | 04:45 PM
crank's Avatar
and im not buying this to say i have a "JDM" engine, it is a killer deal for a crispy motor
Old Apr 21, 2010 | 05:07 PM
AusS2000's Avatar
JDM engines are higher compression. 11.7:1 rather than 11:1.
They also have slightly different sensors. I wasn't aware of the VTEC oil switch but I would assume it isn't a problem. You can use the unit off your old engine. I believe they don't have a knock sensor either which will be important on a higher compression engine running on US fuel. I would guess the mounting point is there and you can use the one off your current engine.
This all assumes you have a current engine. For all I know you could be buying the engine for a project.
Old Apr 21, 2010 | 05:15 PM
crank's Avatar
i have a current usdm engine, basically wat i have read on this forum so far is that they do have a knock sensor and all the sensors are the same, wiring harness is mirrored due to RHD and im in florida we have 93 and i would be usuing my USDM ecu anyhow. I seem to be getting conflicting info
Old Apr 21, 2010 | 05:20 PM
AusS2000's Avatar
Either way it doesn't matter whether they do or don't have sensors. Because you do.
The RHD/LHD thing also doesn't matter because you have a LHD harness. The engine doesn't know where you sit or on what side is the steering wheel. It's not 'mirrored'.
Old Apr 21, 2010 | 05:27 PM
crank's Avatar
the harness enters the car at the opposite side since its rhd so that is what i was refering to by mirrored, prolly a poor analogy lulz ! thanks!
Old Apr 21, 2010 | 05:42 PM
AusS2000's Avatar
I realise what you mean, I just don't see it's relevance.
