ABS light
Old May 9, 2005 | 10:35 AM
S2KenC's Avatar
Default ABS light
Hello folks
Posting this question for a friend of mine. My friend has a 2001 model approaching 80k miles. Car is stock except for an upgraded ACT clutch kit that was installed at about 45k miles.
Recently, the ABS light has been coming on after sitting for awhile. It doesn't go away until about 10 minutes of driving or so. The most peculiar part about this whole problem is that for some odd reason, the Air Conditioning doesn't seem to work at all during this whole ABS issue. Just as the ABS light goes off, the Air Conditioning Fan comes on. It has happened twice already. Coincidence???
I did a search on ABS light and came across another person that had this same problem. Also, people were suggesting that the speed sensor or the ABS sensor to be the culprit? Any help is appreciated. Thanks in advance!!
Old May 9, 2005 | 12:15 PM
VTR_Gary's Avatar
For sure the A/C fan? Or possibly the engine cooling fan?
If its the engine cooling fan, I'd start looking for something like a cold solder joint in the ABS unit...
If its the a/c fan, I'd look at wiring diagrams and find out what the 2 systems have in common. Maybe they share a ground or a power supply. I'd look there.
Old May 9, 2005 | 02:23 PM
S2KenC's Avatar
Thanks for the reply. Its the AC fan. The fan for the air conditioning doesn't come on at all until the ABS light goes off.
Old May 9, 2005 | 07:33 PM
hondamanwill's Avatar
There should be a code stored
Old May 9, 2005 | 08:23 PM
Utah S2K's Avatar
The ABS circuit does a detection and the sets a fault followed by shutting down ABS. My guess is that you have a current draw which is shut off when the ABS code is set. With the shut-off of ABS there is more power available to the other circuits. You need to have someone pull the OBD-II codes. Most auto parts stores will do it for free. Have the codes pulled and then let this thread know what they are. Lots of knowledgable folks here including some of Hondas best mechanics.......best of all it is free.
Utah
peters2000
Nov 30, 2009 10:35 PM
jdmgpw04
Sep 1, 2009 09:25 PM
sokkie9
May 17, 2008 05:29 PM
if lookz kill
Nov 30, 2006 09:20 PM
ImportSport
Apr 7, 2004 11:12 AM
