abs light
Old Apr 4, 2009 | 05:11 PM
s2kbtos's Avatar
Default abs light
i just finished installing my stage 2 rebuilt by puddymod ( He did a great job!). after the installation my abs light turned on. does anybody know why is it on?????
i had to take the lower ball join out in order for me to remove the differential, but i put everything the way it should be.
Old Apr 4, 2009 | 05:39 PM
downloader's Avatar
check the wiring going to the connectors and sensors
Old Apr 4, 2009 | 05:49 PM
Slows2k's Avatar
Most likely cause is you broke a ABS sensor wire internally when you swapped the diff.
Most don't remove the axles, just separate the lower ball joint to get the axles back far enough to pull the diff.
If you the knuckle/axle back far enough you can break the sensor wires.
Old Apr 4, 2009 | 08:59 PM
s2kbtos's Avatar
what color are the abs sensor? would i have to replace the whole thing and how much would it be you think
Old Apr 5, 2009 | 06:32 AM
negcamber's Avatar
It's black. And check to make sure you tightened the bolt all the way down. I've seen a loose sensor cause an ABS light too.
Old Apr 5, 2009 | 08:09 AM
CKit's Avatar
They're pretty fragile. Nowdays, if I'm doing anything with the hub / control arm, I unbolt the sensor and move it out of the way.
Pretty easy to install a replacement one. ~$100 in parts.
Make sure that the sensor is clean and seated ~1-2mm from the ring teeth first. And try driving around for a few miles before replacing the sensor to give the ABS computer a chance to reset if there really isn't a problem.
Old Apr 5, 2009 | 11:11 AM
s2kbtos's Avatar
so if the sensor went bad , cause i damaged it by removing the lower ball joint arm, do i just get a 10 mm socket take the sensor out and just replace it, or does the whole cable coming from the chassi has to be replaced?
Old Apr 5, 2009 | 11:52 AM
s2kbtos's Avatar
ok so i just unbolted it and cleaned it, then drove it 3 times around the block and the abs light still on...
Old Apr 5, 2009 | 08:26 PM
s2kbtos's Avatar
is there anyway that the lower arm is not aligned properly? because when i had to take it off the lower joint in order for me to move the axle.
how can i see if its not aligned properly? cause i just used a jack to put it back where it was, with the castle nut.
AP1Driver
Oct 3, 2013 05:05 PM
Si2k
Dec 12, 2011 08:14 AM
Asura
Aug 2, 2007 08:17 PM
RXDI
Dec 27, 2006 03:43 PM
clanger
Mar 27, 2006 02:59 PM
