ABS Light On From Dealership
Old Aug 21, 2013 | 07:27 AM
bgioan's Avatar
Default ABS Light On From Dealership
Took my car to get my some new keys reprogramed at a local Honda dealership. I gave it to them the ABS light was not on, and once I received it all looked normal except for the fact that the ABS light is now on. I have driven about ~20 miles and it is still on. Would the dealership fix this problem? Just trying to get it sorted out!
Old Aug 21, 2013 | 07:30 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
All they can do is scan the code.
You may be able to blink the code out yourself also. Search it.
Old Aug 21, 2013 | 07:48 AM
bgioan's Avatar
I am not worried about scanning the code. I am going to blink it. However what I am concerned about is that they caused it.
Old Aug 21, 2013 | 08:08 AM
bgioan's Avatar
Not entirely sure how to order the counts. I would get 2 long blinks and then either 2,3 or 4 short blinks.
Old May 15, 2014 | 03:14 PM
bgioan's Avatar
The codes I have apparently are 22,23 and 33. So first issue is how can I check what might be causing each one of these codes to go off together. Must be something and not just them individually. Also again I called the dealership way back when and was told apparently that ABS codes go off by themselves just because the car is old. That is absolutely absurd. I have had this car for such a time and have never had any issues with the ABS system. This is the FIRST time I have given my S2000 to a dealership and this happens after unfortunately.
Old May 15, 2014 | 05:40 PM
joes sled 2000's Avatar
In all honesty , i can't think of a single reason why or how programming keys would have anything to do with the abs . I know it seems fishy , but come on . Don't be so quick to point the finger . Check to make sure the battery isn't low on charge as this can cause bogus codes in various systems . Good luck .
Old May 15, 2014 | 06:40 PM
EricJT7's Avatar
It could possibly be a faulty abs sensor, that's what it was with mine until I recently had a friend change it out for me in approximately 20-30 minutes. Just make sure to get it scanned again until you get a consistent reading, if there is more than one code every time it could be something else as well I would think though.
Artric
Aug 19, 2016 01:18 AM
negcamber
Jan 29, 2007 08:04 AM
S2FiONE
Aug 10, 2006 06:32 PM
Hamiy
Nov 25, 2005 04:07 PM
zzz36
Aug 19, 2005 10:15 AM
