Compression test was good, do I need to do a leakdown test as well?
I did a compression test to diagnose a cylinder misfire problem. Compression was good, if a little high: #1 at 248psi, #2 at 241psi, $3 at 235psi, and #4 with 247psi (average of 3 test results). Tested warm, WOT. Also put in new spark plugs and swapped coil packs around to no avail.
With good compression results, would a leakdown test give any useful information?
Trigun
Oct 3, 2006 11:27 AM
