ABS light please help :)
Old Jun 16, 2008 | 11:05 PM
Hyper_R's Avatar
Default ABS light please help :)
Hey guys,
i have had my abs light come on, and it is throwing a code 15, i have tried the search and am unable to find what this is.
Has anyone had a similar code with their abs? anyone know what the problem might be?
any help is greatly appreciated
thanks
Old Jun 21, 2008 | 10:01 PM
Kirpich's Avatar
This is waht the manual says about it:
Right-rear wheel sensor (open/short to body ground/short to power)
It goes on to say that it's either a bad wire, such as a shorted out wire between the control module and the sensor, or a bad sensor. check wiring, connectors to that wheel. good luck.
Mark K.
Old Jun 21, 2008 | 10:08 PM
negcamber's Avatar
Have you done any work on the brakes or suspension recently? The abs sensors and wires are easy to damage as well as the notched ring on the hub that the abs sensor uses to calculate wheel speed.
Old Jun 21, 2008 | 11:41 PM
Hyper_R's Avatar
thanks for the reply guys , i really appreciate it.
Ill have a check over on the wires and connectors tomorrow and keep you posted.
I have recently had a set of Tein RA coilovers installed so something might have been damaged during installation, but ill check it out soon
thanks
Old Jun 23, 2008 | 10:57 PM
Hyper_R's Avatar
Problem fixed, it was a bad connection at the wire
thanks alot for the help guys.
Really appreciate it.
GTDRIFT
Feb 21, 2017 12:39 PM
OMGJDM
Jul 15, 2011 01:13 PM
Asura
Aug 2, 2007 08:17 PM
Cycloneranga
Aug 19, 2006 12:03 PM
intake
Aug 17, 2004 10:15 PM
