ABS Modulator Control Unit Bleeding
Old Jun 22, 2018 | 05:42 AM
WeS2kay's Avatar
Default ABS Modulator Control Unit Bleeding
Okay, so the circular area on the rear of the ABS Modulator Control Unit has started to accumulate some surface rust on my car, and its frustrates me everytime I look at it. I want to remove it to use a wire brush to clean and paint it. My question is, how do I bleed the ABS unit? According to the shop manual on page 19-59, it states start bleeding with front wheels. So do I just bleed it as i would a traditional gravity bleed or is there a special way to make sure that air is not in the ABS modulator control unit. Thanks for the help!
Old Jun 22, 2018 | 06:24 AM
s2000ellier's Avatar
https://robrobinette.com/bleeding_th...r_cylinder.htm
I used this to bleed my ABS unit
Old Jun 22, 2018 | 06:28 AM
WeS2kay's Avatar
Thanks! That is perfect. So basically add fluid to the reservoir, let gravity help the fluid get down to the abs unit then follow these steps and it should be good to go?
Old Jun 22, 2018 | 08:55 AM
Sure
Old Jan 17, 2021 | 07:53 AM
F1TwoThousand's Avatar
This method doesn't make any sense. After bleeding the master cylinder air would be re introduced when plugging in disconnected line
westy700
Oct 10, 2018 07:31 AM
macr88
Electronics
Nov 30, 2010 04:42 PM
schmittx
Nov 30, 2010 03:21 PM
badboy00z
May 14, 2009 03:07 PM
