ABS system
Old May 7, 2012 | 08:06 PM
BBV S2K's Avatar
Default ABS system
Had a conversation with S~Factor about it and we got to the conclusion... how many times We have heard it working? I only heard the system working 3-4 times during winter and thats it...
question is...
if I remove the whole ABS system... how I do to keep the light off in the dashboard?
I know the ABS light will come on...
reason why we or I want to remove it is for a nice tucked and clean engine bay...
Old May 7, 2012 | 08:34 PM
Stratocaster's Avatar
Remove the bulb.
Old May 7, 2012 | 08:48 PM
BBV S2K's Avatar
Originally Posted by Stratocaster
Remove the bulb.
lol nice one...
forgot to ask... will the brake feeling and precision change? I can stop on a dime right now.. S2K brakes are just wonderful
Old May 7, 2012 | 08:50 PM
SgtB's Avatar
The S doesn't stutter the brakes as much as other cars. The ABS will save your butt at a full stop. It probably helps you more than you think.
Old May 7, 2012 | 08:59 PM
BBV S2K's Avatar
Mmmm interesting... maybe I can relocate the system off the engine bay?
I personally didn't like the wire tuck or clean engine bay (never found it necessary) till I saw S~factors S2K engine bay... and its something I can do myself so im going for it
Old May 8, 2012 | 12:09 PM
305AP1's Avatar
If you DD the car I highly suggest leaving the abs in. The car does feel a lot different under heavy breaking with out abs and like stated above it could save your ass in a tricky situation.
Old May 8, 2012 | 12:55 PM
speedjunky01's Avatar
abs light is on due to a bad sensor I think
I now drive it slow as hell
even with 225f 255r re-01's I lock up without a problem with the hawk hp+ pads if pressure is applied anything but very very smooth.
Old May 13, 2012 | 04:37 PM
S~Factor's Avatar
Try unplugging the wiring on the abs module in the engine bay (or the fuse) and drive around like you normally drive for a week with it. If you don't notice a difference... then... well... you know the answer.
esoteric
Apr 17, 2005 04:21 PM
diskoe
Jan 22, 2003 08:00 AM
