AC clutch broke off the compressor
hey guys, i recently found out that my ac clutch came apart from the compressor. don't know how or why it happened, any info? and does honda sell this clutch part or do i need to replace the whole compressor unit? thanks
btw it is an 03 with and 05 f22 motor. i would like to know if it uses the same compressor or is it completely different?
Looks like it can be purchased separate.
http://www.hondaautomotiveparts.com/auto/j...=A/C+COMPRESSOR
I had a similar issue. Both myself and a friend had A/C failure. Actually all parts are on backorder. I ordered a new compressor and evaporator and managed to get the parts in a week. Only problem is that debris gets sent through the A/C lines when this happens. A/C failures requires a lot of work and the need to either ensure the lines are completely cleaned out or replaced.
Here was mine
Here was mine
