AC Problems
Old Jul 12, 2013 | 10:29 PM
Dstinnet's Avatar
Default AC Problems
My AC in my car is not functioning at all. I bought a can of freon with a pressure check and noticed who ever charged the car last overfilled so was in the red zone. I took it over and had the freon removed and added new freon still blowing hot air. I can hear the condenser kick on when I engage the AC and checked the condenser fan fuse and other fuses and all check out. Anyone have any ideas what could be the problem?
Old Jul 12, 2013 | 10:55 PM
hatchhero's Avatar
are both radiator fans coming on?
Old Jul 13, 2013 | 08:55 AM
franky's Avatar
When you took the car for an ac service they should of fix ur ac problem. Makeup they overfill it too. Did you use ur gauge to check if the pressure is in the right mark?
Old Jul 13, 2013 | 09:59 AM
Wolf95's Avatar
You mean you can hear the COMPRESSOR kick on, not the condensor. You could have a blockage somewhere on the high side which wouldnt show up on your gauge on the low side..
Get a full pressure gauge and compare the high side pressure with the low side.
Old Jul 13, 2013 | 10:46 AM
franky's Avatar
If that was the case, then whoever the op took it to didn't do it right. He got ripe off.
Old Jul 13, 2013 | 01:51 PM
Wolf95's Avatar
Possibly. Some shops do the exact same thing DIYers will do. Purge the system (Legally or illegally) and stick the ol cheapy R134 kit on it and refilled it.
Just depends who he had do the work.
Old Jul 13, 2013 | 06:38 PM
franky's Avatar
You know if u see someone purge the ac illegally n u got a pic of it. U can report them to the BAR n get some big money for it.
I used the regular r134 from walmart n it works great.
skynetMMXII
May 22, 2015 05:35 PM
OHclassic
Mar 14, 2013 02:11 AM
Rocket_Man
Jul 24, 2006 07:25 AM
S2KDRIVER18
Apr 12, 2006 02:56 PM
