acceleration lag
Old May 20, 2009 | 01:13 PM
StReEt2000's Avatar
Thumbs up acceleration lag
HHHHHHHHEEEEEEEELLLLLLLLLLLLLPPPPPPPPPPPPP!!!!! my s2000 is a 2000. when starting from 1st or when ever im below 2k pms and i give it gas it has a huge lag for about a sec or two and bogs down. even if im at 6k rpms and floor it it bogs and makes a low pitch hum until it picks up again. also my check engine light comes on when i first start my car but it goes away after 5sec. i dunno what going on with it and i hope you guys can give me some advice. thanks
Old May 20, 2009 | 01:31 PM
StReEt2000's Avatar
bump...
Old May 20, 2009 | 02:17 PM
negcamber's Avatar
Yeah...no bumping after waiting only 15min. This isn't Honda Customer Service.
Based on your sig...sounds like you have a few mods. List off the engine & drivetrain mods.
It may be your MAP sensor...your mods may impact that guess.
Old May 20, 2009 | 03:55 PM
Burgman's Avatar
Possible throttle position sensor. If the computer does not know you are opening the throttle it will not be able to know to increase the amount of fuel injected into the engine.
Old May 20, 2009 | 06:00 PM
StReEt2000's Avatar
ill list mods but the problem pretty much goes away if i turn off the ac. when this problem was occuring i had the ac on full blast... is there any way to stop this from happening?
Old May 20, 2009 | 06:03 PM
StReEt2000's Avatar
well i know there is unnessary info on this but i just pasted it. dont feal like rewriting lol
Interior:
FULLY-PAINTED S2000 SILVERSTONE METALIC INTERIOR.
SPARCO BLACK REV SEATS, SEAT PADDING SEAT ADJUSTORS, FOUR POINT RACING HARNESSES AND CARBON SHIFT KNOB.
HP RACING STEERING WHEEL.
SPOON STEERING HUB.
A'PEXI TURBO TIMER.
AUTO METER GUAGES (EGT AIR/FUEL, BOOST).
FULL LEATHER CONSOLE COVER.
Exterior:
L-CREATION JDM FRONT END, SIDE SKIRTS, AND REAR END.
CUSTOM-MOLDED WIDEBODY KIT BY CUSTOM AIR WORKS.
GTP C-WINGS CARBON-FIBER SPLITTERS.
HONDA OPTIONAL EQUIPMENT BLACK BADGES.
STREET GLOW UNDERCARRIAGE NEON LIGHTING KIT.
JDM S2000 HEADLIGHTS AND SIDE MARKERS.
JDM 2002 S2000 TAILIGHT CONVERSION.
BLACK REFLECTIVE SPONSORS VINYL SCHEME.
CARBON-FIBER GAS CAP COVER.
CUSTOM CARBON FIBER HOOD.
Engine:
2.0L DOHC VTEC.
COMPTECH USA SUPERCHARGER, FUEL RAIL, CARBON-INTAKE, AND FUEL PRESSURE REGULATOR.
NITROUS EXPRESS INTERCOOLER SETUP, CUSTOM S2000 SILVER NITROUS BOTTLE, BOTTLE PRESSURE GUAGE, PURGE KITS, AND REMOTE BOTTLE OPENER.
POLISHED CUSTOM UPPER INTERCOOLER PIPING, LOWER INTERCOOLER PIPING, AND END TAKES.
XS ENGINEERING 24X14X3-INCH INTERCOOLER.
TURBO XS BLOW-OFF VALVE.
MUGEN THERMOSTAT AND HIGH-PRESSURE RADIATOR CAP.
POLISHED VALVE COVER, INTAKE MANIFOLD, AND BATTERY TIE-DOWN.
CROME ALTINATOR.
RM RACING ENGINE DRESS-UP KIT.
A'PEXI AFTER-CAT EXAUST.
ACT CLUTCH KIT AND STREET CLUTCH DISC.
KAAZ USA LIMITED SLIP DIFFERENTIAL.
COMPTECH USA LIGHTENED FLYWHEEL.
Suspension:
BILSTEIN COILOVER.
COMPTECH USA FRONT STRUT TOWER BRACE, FRONT LOWER BRACE, MID BRACE, REAR LOWER BALANCE, ANTISWAY BARS.
ENKEI PHALENX WHEEL (18X8.5 IN FRONT, 18X10 IN BACK).
BRIDGESTONE SO3 POLE POSITION TIRES (225/35ZR18 SO3 IN FRONT AND 265/30ZR18 IN BACK).
GORILLA LIGHTWEIGHT LUG NUTS.
BRAKE MAN BIG BREAKE KIT (INCLUDES 12.19 INCH-INCH CUSTOM CROSS-DRILLED REVOLUTIONARY ROTORS, CUSTOM FULLY-POLISHED 2-PISTON FRONT AND REAR CALIPERS, AND BRAKE PADS).
In Car Electronics:
VDO MS 5000 NAVIGATION UNIT, TV TUNER, DVD PLAYER, HEAD UNIT, AND MULTIMEDIA BOX.
MB QUART COMPETITION CUSTOM MOLDED TWEETERS, 5.25-INCH MID-RANGE SPEAKERS, 10-INCH SUBWOOFER AND CROSSOVERS.
CUSTOM FIBERGLASS BOX, SCOSCHE WIRING, CUSTOM INSTALLED MILDED DASH.
Old May 20, 2009 | 07:29 PM
Suzukuh's Avatar
Well having your ac on saps some power from the engine. It's definitely noticeable.
Old May 21, 2009 | 10:18 AM
negcamber's Avatar
Well...with all those engine mods it is going to be really tough to diagnose.
I didn't see you mention what you use for engine management. AEM EMS?
What are you seeing with the AFRs when this happens? Any change in EGT?
I would bring it to your tuner and take a look at the data logs.
Old May 21, 2009 | 10:37 AM
EVAN&MONICA's Avatar
sounds like a good thing to ask maybe in the FI forum... good luck!
Old May 21, 2009 | 10:47 AM
DFWs2k's Avatar
i bet it's the ALTINATOR, our cars should use an object known as an "alternator"
seriously though, since you're FI, i would post in that forum, but with better grammar/spelling
AS FAR AS THE A/C GOES:
when you go WOT, the car should automatically be putting the A/C on "hold" (for lack of a better word) to give your engine full power
