Access knock sensor
Old Oct 15, 2009 | 09:01 PM
AusS2000's Avatar
Default Access knock sensor
With the engine in the car how do you access the knock sensor?
From the top?
From underneath?
From the front?
And also does anyone know what size socket it is?
Old Oct 15, 2009 | 10:16 PM
s2k dre's Avatar
Its a 23mm! I replaced it from bottom! Its a pain.
Well, mine was 24mm. YMMV. Aus
Old Oct 15, 2009 | 10:43 PM
AusS2000's Avatar
Thanks, needed that.
What the hell did you get in there from the bottom?
I now have my alternator and battery (RHD) removed but the biggest socket I have is 22mm. Damn!
Old Oct 16, 2009 | 12:33 AM
s2k dre's Avatar
Its a nightmare! U can remove the intake if u have to but its really a tight fit.
Old Oct 16, 2009 | 02:35 AM
chris_barry's Avatar
try a 1" tube spanner. They type they sell to change tap washers may do. It will be loose but should have enough engagement to remove it.
Old Oct 16, 2009 | 03:03 AM
AusS2000's Avatar
I'm gunna pick up a 23mm socket tomorrow.
I have the battery out (RHD), the fuel rail and injectors off and the hose below the intake manifold pulled out of the way.
With the right sized socket I should be good to go.
Old Oct 16, 2009 | 04:09 AM
A few people have posted the size as 24mm and 25mm in other threads so keep the receipt for the socket.
Old Oct 17, 2009 | 05:54 PM
AusS2000's Avatar
I figured I'd play it safe and add a 23, 24, and 25mm socket to my collection. Bunnings only had 23 and 25 so I bought both.
Turns out it's a 24.
Old Oct 17, 2009 | 07:18 PM
Slows2k's Avatar
24mm is the one.. You'll need a deep socket. I reach it from the top under the manifold.
Old Oct 17, 2009 | 07:49 PM
CKit's Avatar
Boo to people who post before they know. Sorry that you got bum info to start. It is a PITA. It's kind of a blind access. Good luck!
