Actual name of the Vtec solenoid?
Old Dec 7, 2014 | 07:32 PM
Shaney's Avatar
Default Actual name of the Vtec solenoid?
#12 in the picture from this link
http://www.hondaautomotiveparts.com/...=CYLINDER+HEAD
Is that the Vtec solenoid? They call it a valve assembly spool on there. My solenoid is leaking and I'm wondering if I need #14 in that picture to fix it.
Thanks
Old Dec 7, 2014 | 08:55 PM
pelayo114's Avatar
Yes the vtec solenoid is called the spool valve.
I can't remember exactly if it only has the head to solenoid gasket or if it also has an o-ring on the top part of the vtec solenoid.
Old Dec 8, 2014 | 01:40 PM
Slowcrash_101's Avatar
It has both, and only the screen filter gasket can be replaced, if the top one starts leaking, you'll need a new VTEC solenoid.
Old Dec 8, 2014 | 03:17 PM
Shaney's Avatar
Thanks guys.
Also, is there another sensor or something below the vtec solenoid? I can't tell if my leak is coming from the vtec solenoid or the thing right below it.
Noob question, do I need to drain the oil to take these off or is the oil below that level when the car is cold?
Old Dec 8, 2014 | 05:31 PM
CoolGuy094's Avatar
Nah you're good to take the solenoid off. It may drip a bit, just put a rag right under it. But the oil level is well below it.
Old Jan 5, 2015 | 11:45 AM
Klutzy's Avatar
Quick question. I'm experiencing the same issue with a leaky valve assembly. Dealership of course recommended that I replace the whole assembly.
Were you able to do this yourself, or did you have someone do it? I've yet to take a look at the service manual and sometimes it's difficult to gauge how difficult the job really is.
Old Jan 5, 2015 | 01:10 PM
CoolGuy094's Avatar
Its very easy to do yourself, and likely all you need is a new gasket not a new entire assembly. I think its three bolts that hold the solenoid onto the head; 10mm socket.
Old Jan 5, 2015 | 05:10 PM
Old Jan 6, 2015 | 07:40 AM
Klutzy's Avatar
Thanks for the response. Probably gonna save me a couple hundred bucks!
Old Jan 7, 2015 | 08:30 PM
dc2-2-ap1's Avatar
Thanks guys.
The tct (timing chain tensioner) is below the Vtec solenoid. The o-rings on them have been known to cause a leak.
There is a sensor on the front portion of the Vtec solenoid that can crack and allows oil to pass through it and exit out of the connector.
I recommend replacing the 3 mount bolts, and torque them to spec. Those bolts will stretch when tightened, so if they have been removed/reinstalled a few times the bolt becomes weak and can break off in the head.
driftqueen
Jan 22, 2015 08:12 AM
lopez14
Dec 3, 2013 06:12 PM
S2000_Europe
Nov 3, 2005 06:00 AM
goneverything
Jul 8, 2004 04:16 PM
