adding oil
Old Sep 23, 2006 | 12:07 PM
kikicha's Avatar
Default adding oil
hey, i bought an s2000 2 months ago and know its time for a extra oil, getting a little low. All it says on this sticker is that the person used mobil 1. what should i do? i'm not sure if its normal of synthetic
Old Sep 23, 2006 | 12:11 PM
S2kracka's Avatar
Mobil 1 is a synthetic. Mobil Drive Clean (Clean 5000) is a conventional.
Old Sep 23, 2006 | 12:21 PM
kikicha's Avatar
thanks, and 10w30 would be the correcty viscosity right? sorry, i'm a complete noob at this
Old Sep 23, 2006 | 12:26 PM
Hockey's Avatar
Yes, 10w30.
Old Sep 23, 2006 | 12:41 PM
cdelena's Avatar
Use any quality 10W30 oil to top off, conventional or synthetic.
Old Sep 23, 2006 | 01:37 PM
fastD's Avatar
How many miles on the car since the last oil change? You may want to change the oil and filter just for the piece of mind...
Old Sep 23, 2006 | 02:05 PM
SpitfireS's Avatar
And please don't overfill it.
Check oil level with a cold engine, parked level (as level as possible)
It takes 1(one) quart form bottom X to top X.
Old Sep 23, 2006 | 07:07 PM
MitsukillinS2K's Avatar
i wouldnt mix the two id just keep using mobile 1 thats all i use and thats all ill ever use
Old Sep 23, 2006 | 07:40 PM
cdelena's Avatar
1. He doesn't know what is in it, only what is on a sticker.
2. All quality motor oils are compatible and mix just fine.
3. What you do and all you would use does not really answer the question.
Old Sep 23, 2006 | 07:56 PM
xviper's Avatar
Ever hear of synthetic blend?
