adding vortech supercharger ?
Originally Posted by New Concept,Jan 14 2005, 02:24 AM
Actually, it is you who is incorrect. But I dont blame you, I wasnt specific enough.
To answer your question: you CANNOT dyno-tune the stock ECU. Well, maybe with a piggyback...but then it's not really "stock" anymore, is it?
Originally Posted by xviper,Jan 14 2005, 08:36 AM
Here is what you posted:
Please note the terms and sentence structure that you used. Based on this, I was not incorrect. We can only answer based on what you type. Good luck on your project. I'm done here.
No hard feelings
xviper, you said that once you get to 350 hp things will start to break. Although its been said when you add a vortech supercharger itll bolt on without problems. Adding a vortech supercharger will add 108 hp at a safe 8psi. thats 348 hp, i guess thats not 350 hp but that seems to contradict what you said. Adding a supercharger is safe but yet adding one will increse it to an unsafe hp? Just trying to figure out whats what.
I am thinking of adding a vortech supercharger with an aftercooler. With that is it still necessary to add an intercooler or does an aftercooler take the place of one. I know i would have to add like a stage 3 act clutch with like 3000 lbs. But i've heard that either the drivetrain or differential will go bad pretty easilly. Im not which one, which one is it? I've also researched that if one does the cryogenic treatment to it then the problem of it breaking down seams to stop.
I was also wondering if one could add a cold air intake to an s2000 with a supercharger installed already. Sorry I have always done my research on turbos and have never thought of getting a turbo so im new at this. I decided on a supercharger because since the engine is already tuned to the max i would have to keep my forced induction down to about 8 psi anways so since turbos usually have the advantage of higher psi, i will not be using that anyways. Plus superchargers dont requier nearly as much tuning and there more reliable. But anyways thanks for your time. and sorry for how long this thing is.
Sorry for not specifying this before. It's generally common knowledge when talking about output that 300 WHP is the typical for a Comptech or Vortech stock setup.
There is less need for a CAI with an "cooler" on the supercharger setup. It will already cool the charge down significantly. Although the Vortech and Comptech both draw air in the same fashion as a CAI anyway.
280 hp eh. i wouldnt be too happy about that.. maybe a turbo would be better? payin 5 to 6 grand for 40 hp seem like a rip off to me. if you added headers, downpipe and an exhaust youll probably reach the infamous 300 rwhp mark.
