adding vortech supercharger ?
You can achieve 300 WRHP with an SC, but you will need a higher boost SC pully (smaller diameter), new external engine managment and possibly larger injectors, to be sure of having a reasonably reliable ride.
Once you have reached your magic figure you will need to use the power carefully or you will burn out the clutch and shatter the differential. You can of course renew these items as well but of course this will mean extra money.
Try 280 RWHP as a first step you can always go for more later!
I think it is unlikely you will get 300 RWHP without tuning.
Assuming most S2000's put down between 190 and 200 RWHP you would require at least a 50% increase in power from the SC. An out of box installation will not deliver this, however depending on the type of dyno you are using you could see figures around the 300 mark.
Originally Posted by xviper,Jan 18 2005, 05:53 PM
Take it easy! He meant no harm, nor did he break any forum rules. Misunderstandings about HP and WHP happen all the time. These things merely need to be clarified. You only need to ask for clarification or point out the discrepancy. There is no need to get "hostile". Until rules are broken, ALL are welcome here.
BTW, does anybody know how the s/c will affect the factory warranty?
Dyno results can be seen here: https://www.s2ki.com/forums/index.php?showtopic=176722.
Big Burp, What was your pre SC dyno RWHP on the same machine?
Perhaps your dyno is just reading high they are not all that accurate from dyno to dyno that's why you really need a before and after measurment.
What I'm trying to say is that given the stock boost from the Vortech you will not get more than +/- 45% power increase without tuning and/or more boost.
Unfortunately, I don't have a "before" dyno to compare.
