adjusted my valves; findings at 16,000 miles
Did my valves tonight...here's what they read before adjustment
Intake, front to back .010,.010,.009,.011,.010,.010,.009,.010
Exhaust, front2back .011,.011,.012,.012,.011,.011,.011,.012
Intake range is from .008-.010, so 1 valve was out of range.
Exhaust range is from .010-.011, so 3 valves were out of range.
I re-adjusted all 16, putting the intake at a "snug" .008, and the exhaust a snug .010. If it was done by the dealer, 4 valves would have been adjusted (you would think). I'll let you guys know if I feel a difference in the car...
Could you tell any differnce? I have an '00 that is running a little on the rough side, and I believe this may be the problem. From what I could take from the dealership the car had not had anything done but regular maintence. So I'm wondering if this will help.
Pardon my ignorance but why do the valves need adjusting? Does the car have hydraulic or solid lifters? cuz usually hydraulic lifter engines don't need valve adjustment right?
would it be right to do a valve adjustment on an 00? with 11k miles? the owner never drove the car. i think valve adjustment are from what i heard is if u most of the time take it up in the higher rpms, making the valves lift higher and higher.
I used to have a B16A3 in a Del Sol, that had 54,000 miles when I got it. The valves may have been adjusted by the dealer by the original owner. I checked them after I put a little over 60,000 hard miles on this car (8,100 RPM all the time) and believe it or not, they were all within .001". I adjusted them anyway. It takes a special tool, and they are hard to get to. I made sure the nut was real tight while retaining proper adjustment. It definitely takes practice
