Adjusting Headlights
Old Apr 11, 2007 | 03:42 PM
jack.tsu's Avatar
Default Adjusting Headlights
Okay, I have looked at the adjuster for the headlights many times now, and I just cannot figure out how a phillips head screwdriver adjusts it.
Can someone please fill me in? thanks!
Old Apr 11, 2007 | 03:51 PM
BennyS02's Avatar
Here is a link on how to do it. http://www.modifry.com/freebies/old/zenon/index.htm
But to tell you the truth you would be alot better off taking the car to Honda and paying them the money to get them aligned to spec. I tried and ended up with them to low and alot of scratches.
Old Apr 11, 2007 | 03:57 PM
jack.tsu's Avatar
The instructions at modifry say where the adjuster is, and to use a phillips head... but not how to do it... I guess I am just not "getting it"
Old Apr 11, 2007 | 04:11 PM
BennyS02's Avatar
Well actually I used a socket wrench. You need an extension and a socket that swivels. That is the best I can explain it.
Old Apr 11, 2007 | 06:50 PM
minh's Avatar
the adjusting knob has teeth that catches onto the phillip screw driver's head when you turn it
or you could use a socket and turn the nut in the back of the knob...thats what i do
silentdancer's Avatar
i used a socket on mine.
Old Apr 11, 2007 | 07:05 PM
iDomN8U's Avatar
Socket was much easier... much
Old Apr 11, 2007 | 09:56 PM
RACER's Avatar
I have done it, but like the other's said, it's more difficult with the phillip's head.
If your not carefull, the screwdriver will skip. A 10mm 1/4" socket with extension on a 1/4" rachet is the way to go
You can see the 10mm adjuster bolt in the pic.
Old Apr 11, 2007 | 09:58 PM
RACER's Avatar
*Above pic courtesy of Modify*
Mnefisher
Jun 23, 2016 09:51 AM
dollag
Feb 22, 2008 03:39 AM
dmcfan
Jan 8, 2005 11:52 AM
solid
Jul 14, 2004 12:51 PM
Barry
Jan 13, 2001 04:01 AM
