Advice on condition of bore please
Old May 8, 2018 | 11:05 AM
  #21
s2000Junky's Avatar
Gorilla snot? Again news to me!
Old May 8, 2018 | 11:27 AM
  #22
fatjoe10's Avatar
I can make a video if you all want haha. Kidding aside, The plating of the alum pistons is stated in that paper also. The piston is hyper-eutectic Al-Si but only the skirts are iron plated, as the magnet won't stick anywhere else except there.
Old May 8, 2018 | 11:32 AM
  #23
s2000Junky's Avatar
That crossed my mind, interesting.
Old May 8, 2018 | 11:36 AM
  #24
fatjoe10's Avatar
Yes, the thrust surfaces of the piston is the only thing that needs it. In theory, I could grab any off-the-shelf 2618 or 4032 piston and have it iron plated to make it FRM friendly as long as the proper P/W clearance is maintained.
Old May 8, 2018 | 12:38 PM
  #25
Slowcrash_101's Avatar
OK, I was wrong. TIL
Old May 8, 2018 | 01:35 PM
  #26
s2000Junky's Avatar
Expansion rate and clearances is still a key element though between the various combinations ie forged aluminum pistons, FRM, iron bores etc.
Old May 8, 2018 | 02:04 PM
  #27
noodels's Avatar
Also was told coating the bore is an option <if over+.25 max o/s piston needed>& if using a non oem piston 2618 & 4032,but piston slap from cold & expansion reduces longevity 20k +/-iirc & even using the .25 os oem could work,but again longevity may not be cost effective.
Wet/dry liner inserts will have the above longevity issue also, piston 2618/4032 only options.
I bought another engine
Another use for my old pistons though as a post it for notes using a magnet
Old May 8, 2018 | 02:37 PM
  #28
s2000Junky's Avatar
Yep, why i stay away from "built" engines for this car. Typical iron sleeve/forged piston to wall clearances have to be larger then oem and that means piston slap and less longevity.
Old May 8, 2018 | 03:00 PM
  #29
fatjoe10's Avatar
Mahle has the 4032 piston with the correct coating... either iron-phosphate or something along the lines of Ni-P-BN. I agree that larger P/W clearances do not lend themselves well to longevity. Then again, who else makes a 4032 s2000 piston for iron sleeves? that's the issue.
Ethan Reynolds
Dec 30, 2018 03:54 PM
RAIN H8R
Aug 12, 2016 09:10 PM
s2kheth
Apr 8, 2015 02:00 AM
vansman
Feb 15, 2015 06:20 AM
stena
Jun 8, 2006 08:07 PM
